Cannot execute Generated processes
olapc
OLAP Product: Planning, TM1
Version: 9.5.1
Post by olapc » Fri Oct 19, 2012 11:34 am
I have tried to make various process links in Cognos Express Planner 10.1. After I generated the process and try to execute it it gives me this message Error: Prolog procedure line (26): Name "}TITmp.source.CAMID("CognosExpress:admin").19285.603564815" contains an invalid character.
Anyone else experiencing same problems? The Prolog procedure line varies from link to link and does not contain anything specificthat should cause this error. In this case the line contains the following: ViewCreate('Tulosbudjetti', varRunSrcViewName );
It seems this has something to do with user rights, but there shouldnt be any invalid characters. Any ideas what is causing this and how to fix this problem?
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Re: Cannot execute Generated processes
Post by Duncan P » Fri Oct 19, 2012 2:51 pm
It looks as if it is trying to create a file with that name. Unfortunately you can't create a file with a colon (:) in the name.
As a work-around is it possible to change the CAMID for the Cognos Express admin, or is that a built-in account?
lcvargas
Version: 10.1.1
Excel Version: 2002
Post by lcvargas » Thu Nov 08, 2012 9:46 pm
http://www-01.ibm.com/support/docview.w ... wg21616578
This is from IBM and I was able to generate my process after I did the following.
Insert the following lines of code (text in bold) in the prolog section after those 2 lines :
#For use in generating per-run unique object names
uniqueRunSuffix = TM1User() | '.' | NumberToString( NOW );
#Check for illegal characters that may cause naming problems
stripChrs = '"'':/\=, ';
stripChr = SUBST(stripChrs, 1, 1);
stripChrs = DELET(stripChrs, 1, 1);
WHILE ( LONG(stripChr) > 0 );
stripChrIdx = SCAN(stripChr, uniqueRunSuffix);
WHILE ( stripChrIdx > 0 );
uniqueRunSuffix = DELET(uniqueRunSuffix, stripChrIdx, 1);
END;
END;
rmackenzie
Post by rmackenzie » Thu Nov 08, 2012 11:26 pm
That's a bit ugly.
I would be tempted to try:
sClientAlias = ATTRS ( '}Clients', TM1User(), '}TM1_DefaultDisplayValue' );
sUniqueRunSuffix = sClientAlias | '.' | NumberToString( NOW );
Robin Mackenzie
Duncan P
Post by Duncan P » Fri Nov 09, 2012 10:03 am
Can the default display value be guaranteed not to contain characters illegal in file names?
If not then you still have to have the code to go through the stripping process - just in case.
rmackenzie
Post by rmackenzie » Mon Nov 12, 2012 9:32 pm
Duncan P wrote:Can the default display value be guaranteed not to contain characters illegal in file names?
Damn, no it can't - it could have \ as the separator of the namespace and client name... back to the drawing board then.
Robin Mackenzie
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Post by Andy Key » Tue Nov 13, 2012 7:22 am
Why bother with the TM1User() at all?
If this is only being used to attempt to guarantee uniqueness of the name, isn't NumberToString(Now) likely to be good enough? What are the odds of two users executing the same process within 1/10,000th of a second? (I think I've got my maths right on the number of decimal places that NumberToString(Now) returns.) And if you think that that is too likely, then pre-fixing with the TM1User() doesn't stop the same user executing the process from two different interfaces at the same time anyway.
Andy Key
Duncan P
Post by Duncan P » Tue Nov 13, 2012 10:00 am
Although NOW may return a number that looks very precise the granularity is in fact one second.
If you multiply the value returned from NOW by 86400 ( the number of seconds in a day) you will always get something very close to an integer.
You could also, as I have, loop a large number of times (e.g. 10,000,000) inserting the result of NOW as an item in a test dimension, then see how many unique items it created.
count       10000000
start       35415.000000084
finish      35474.999999965
duration    59.999999881
unique      61
granularity 0.983606555
Tilo
Post by Tilo » Thu Feb 07, 2013 4:59 pm
I used NumberToStringEX() instead of NumberToString() to replace the comma separator (","-->".") that you get when using NOW() and having a german number format configuration.
uniqueRunSuffix = TM1User() | '.' | NumberToStringEx( NOW , '#,0.#########', '.','.');
kaazimraza
OLAP Product: TM1, SSAS, Power BI
Post by kaazimraza » Fri Feb 20, 2015 6:41 am
Hi guys,
I am getting this error, in my case, in a process I have created using Architect. My environment is TM1 10.1.1 and I have used Architect to create the process. Any idea what could be the resolve ?
Kaz
