Day of Week in TI
- Version: 9.4
- Excel Version: Office 2003
Day of Week in TI
I search a function to find the day of the week in a TM1 process.
So, for example: 1 = Sunday, 2 = Monday, ..., 6 = Saturday.
I now the format for day of the week is \w but in wich function do I have to use this format?
Because in the TIMEST() function, dus format is not supported...
Can anyone help me please? Thanks!
{Admin Note: This was moved from the Useful Code, Tips and Tricks forum. The answer may be useful code. The question isn't.}
- Alan Kirk
Re: Day of Week in TI
First you need to get the date into a DateSerial format. The Today() function will give you the serial date of the current day. Otherwise, use the DayNo function.nickmas wrote:I search a function to find the day of the week in a TM1 process.
You can then use the following, though it returns Sunday as 0:
# 0 = Sunday, 1 = Monday to 6 = Saturday.
l_DayOfWeek= Mod ( DayNo( TODAY ) + 21915, 7);
- Version: 9.4
Ok, thank you very much!!
But why + 21915?
But why + 21915?
- Alan Kirk
It's the difference in serial dates between TM1's system (which starts on 1/1/1960) and Excel's (which starts on 1/1/1900). It would be possible to do a similar calculation using TM1's date system alone but there's sometimes a need to do conversions to and from an Excel date serial number so I just find it easier to leave that in.nickmas wrote:Ok, thank you very much!!
But why + 21915?
- Version: 9.4
Ok, thanks!
So I can just use that code in my TM1 process and it will work?
(I can not try it now, because I am not @ the office)
- Alan Kirk
Yes; I just have it in my code library as a "copy and paste" block. But as I said, this one renders Sunday as 0, not 1. You can modify it accordingly. (Just add 1 to it.)nickmas wrote:Ok, thanks!
- Version: PAL 2.0.9.18
Resurrecting from the deads but with good information:
# weekday '1' = Sunday, '7' = Saturday
sWeekday = NumberToStringEx( Now + 21916, 'w', '', '' );
# 1 = Sunday, 7 = Saturday
iWeekday = Numbr( NumberToStringEx( Now + 21916, 'w', '', '' ));
# weeknumber 1 to 54
sWeeknumber = NumberToStringEx( Now + 21916, 'ww', '', '' );
# quarter '01' to '04'
sWeeknumber = NumberToStringEx( Now + 21916, 'q', '', '' );
IBM Champion 2024
IBM Champion 2024
- Alan Kirk
I'm aware that I need to update ye olde Using Dates And Times thread with that as well, but I need to update it with a number of things. Right at the moment I'm testing out issues relating to the new Excel Dates server config parameter and plan to whack the whole thing with a complete overhaul.
That would be good, thanks !
Too bad that this:
(mind the C) gives colons in the output. For me, currently:
Sat Jun 29 00:49:04 2019
If not I could use it in temporary views and subsets, as a replacement for a long Timst statement.
Too bad that this:
NumberToStringEx( Now + 21916, 'C', '', '' );
IBM Champion 2024
IBM Champion 2024
- Excel Version: 2013
I got stuck on trying to figure out the location of the tm1s.cfg. Also how general thing should be to work with both windows and linux machines. Then I had too many variables on my list and gave up.
Are you an admin person of that TM1 model, or what is your role with respect to TM1 ?
IBM Champion 2024
IBM Champion 2024
Yes I'm an admin/developer. I was working on some sort of "ultimate period/time dimension creator". But to calculate some things I needed to know where the tm1s.cfg file was located. Since I need to know if the model used tm1 dates or excel dates.Wim Gielis wrote: ↑Tue Jul 02, 2019 8:56 am Are you an admin person of that TM1 model, or what is your role with respect to TM1 ?
The only real practical solution I could think of was to store it in a control cube somewhere. But at that point I was on to new adventures. If I had more time I would try to find the answer using the REST API. It seems its a magic answer to most things. If so i could just create a .cmd script that in theory would work on both windows and *nix machines.
Now that I think about it I would probably end up storing the result in a cube somewhere anyway. So maybe just build the thing and worry about automatically populating the cube later.
Take a look at this link for tm1s.cfg :
https://www.ibm.com/support/knowledgece ... 5038e.html
And this one for more explanation on the UseExcelSerialDate parameter:
https://www.ibm.com/support/knowledgece ... ldate.html
Cheers !
Cheers !
Emixam wrote: ↑Tue Jul 02, 2019 4:24 pm And this one for more explanation on the UseExcelSerialDate parameter:
It never even occured to me to derive the system used by checking the output. Now you made me feel like a complete idiot
Thanks a bunch!
Will try to find some time to rebuild my dim.period process.
