I use a TI process to re-create a few default views after rollover. I was surprised to find out that I forgot to turn on Auto Recalc. and couldn't find a way to do it in TI.
Is there any way to accomplish this without manually opening and saving each view?
Thanks!
Kenneth
Cube View Created by TI with Automatic Recalculation On
- Version: 10.1.1
- Excel Version: Excel 2010
Re: Cube View Created by TI with Automatic Recalculation On
I don’t think you can set this in a TI or the API, which is a bit of an oversight (unless I missed something).
If you look in the actual .vue file then you should see the line 376,0.
This, I think, indicates that the auto reclac is off. To switch it on change to 376,1.
So maybe some sort of powershell script to replace 376,0 with 376,1 in the Default views?
Or if there are not too many views then do it manually!
regards,
Mark
regards,
Mark
- OLAP Product: Cognos
- Version: Planning Analytics 2.0.7
Thanks Mark. It's disappointing but I guess I will live with it.
Ken
Ken
