Excel SumIF in TM1
AlphaWay
Excel Version: Version 2003
Excel SumIF in TM1
Post by AlphaWay »
I got a requirement of SUMIF calculation to be done in TI process as below ,
For Eg:
Column A | Column B | Column C | Column D
India | 5 |10 | Calculated Value
SG | 10 | 20 | Calculated Value
SG | 10 | 25 | Calculated Value
India | 45 | 15 | Calculated Value
Column D(Calculation formula)
=(SUMIF($Column A$1:$Column A$4,Column A,$Column B$1:$Column B$4)/SUMIF($Column A$1:$Column A$4,Column A,$Column C$1:$Column C$4))
I understood that the result should be,
India ,50 / India , 25 = Value
SG , 20 / SG , 45 = Value
India = 2
SG = 0.44
Kindly suggest me to achieve in TI Process calculations.
TIA
TIA,
Wayfarer
Version: PAL 2.0.9.18
Re: Excel SumIF in TM1
What is the cube structure ?
What is the structure of the dimension that contains India and SG ?
IBM Champion 2024
AlphaWay
Post by AlphaWay »
It's a Measure dimension.
Cube has total of 5 dims where "Item" is Row dimension set and "Measure" is Column dimension
TIA,
Wayfarer
HighKeys
OLAP Product: TM1 / TM1 Web / Perspectives
Version: Planning Analytics V2.0.9
Post by HighKeys »
first you have to create a view then subsets for all dim's, after this you can loop though the view and calculate what you want.
For sum if just is an If, like
If(vDimforColA @='India);
nSumIf = nSumIf + 'India';
EndIf;
best Regards
MarenC
Excel Version: Excel 2016
Post by MarenC »
he might be able to do cellget if the dimension structures allow for it? I thought that was the point of TM1.
Maren
HighKeys
Post by HighKeys »
As i know, it's more performant if you loop though a view rather then using CellPutN(CellGetN(.....)....);
But yes would also work.
MarenC
Post by MarenC »
Hi Highkeys,
well that depends on how the dimensions are structured I would think. If he just needs the elements from dimension A and the rest can be hard coded values, so consolidations from the other dimensions and a measure, I wouldn't see any need for a loop as such.
If the if part is sumif is for specific attributes or something else not mentioned then yes views and loops might be required.
But generally speaking wanting the total sum of an element in a cube for a given measure is what TM1 is designed for, at least in my mind it is!
Maren
HighKeys
Post by HighKeys »
MarenC wrote: Wed Aug 05, 2020 9:42 am ....
Maren
Yea totally agree! :geek:
AlphaWay
Post by AlphaWay »
All columns mentioned are from same "Measure" dimension .
Scenario
Scenario
Sum If function inside TI process is not working.
Inv % column is my result column and mentioned formula is the one i am trying out.
TIA,
Wayfarer
HighKeys
Post by HighKeys »
Please post your TI code.
