Corrupt CAMKeystore when using IBM Cognos Configuration in 2.0.9.1
Posted: Sun Jul 26, 2020 4:41 pm
Not sure if I am the only one blessed with this, but I've logged a ticket for this with IBM
During installation of PAL 2.0.9.1 we have found an issue with starting the "IBM Cognos TM1" service.
We have custom certificates for all the bits outside Architect (using the IBM one for this).
We have found that when starting the "IBM Cognos TM1" service from the Windows Service application, we can log into TM1Web using our ceritifcates and all is good.
However, if we try to use "IBM Cognos Configuration", the second we start the service, the CAMKeystore gets corrupted and we are not able to connect to TM1Web.
When this happened, I opened the CAMKeystore file using ikeyman.exe and it confirms that the CAMKeystore is the problem.
When investigating this, I noticed that the size of the file reduced when launching via IBM Cognos Configuration, suggesting that something is being overwritten at the time of the service starting.
Has anyone else noticed this ?
Ajay
Ajay
