Looping in a Daily Dim
- OLAP Product: TM1 / TM1 Web / Perspectives
- Version: Planning Analytics V2.0.9
i try to create a TI Loop that goes through all Days in a specific year (Day is the Element Level 0), in the loop i will do some calulations and write back the result in a cell at this day.
I think i have to create a subset and loop through the subset, would be nice if someone has a snipped from something like that (create subset an loop through it), i cant find any information in Google, or i'm just bad at google search.
Thanks for your help!
- orlando
- Version: PAL 2.0.8
Re: Looping in a Daily Dim
a short idea what do to. You have finalise by yourself.
Take a look here
https://www.bihints.com/book/export/html/68
this gives you all N elements of a parent
{TM1FILTERBYLEVEL({DESCENDANTS(Product.[Customer Lending]) }, 0)}
https://www.ibm.com/support/knowledgece ... tsize.html
SubsetGetSize - lets u know the number of elements in a subset
https://www.ibm.com/support/knowledgece ... tname.html
SubsetGetElementName - gives the element by index
the loop
i=0;
numElem = SubsetGet.....
while(i<=numElem);
sElem = SubsetGetElementName(DIm, Subset, i)
Do whatever you want
i=i+1;
end;
Best regards
orlando
Take a look here
the loop
i=0;
while(i<=numElem);
i=i+1;
end;
Best regards
orlando
Awesome! Thank you so much!
I will post my code after i'm done!
Now i got a additional question, i set up my loops and calculation but if i trace the loop via ASCIIOUTPUT i see that its just looping the inner While and not the others..
i Build the Loops like:
Just the while(c <= d); loops correct. Is it not the correct syntax?
Thanks and KR
While(x <= y);
do something
while(c <= d);
do something else
end;
end;
Thanks and KR
Hey Orlando, got my mistake, forgot to set the counter in the inner loops back to 1 thats why the loop just run once.
Here is my prolog script:
Very bad code, i think its totally vs best practice but it works.
Thank you so much for your help!
#pFilter = 'Jahre: '|pJahr|' & Version: '|pQuellversion;
#build subsetname
sSubsetName = 'tmpCappingCalc_TI_' | today(1);
nProdCap = pProdCap \ 100;
#create tmp Subsets
if(SubsetExists('Tag', sSubsetName) = 1);
SubsetDestroy('Tag', sSubsetName);
EndIf;
if(SubsetExists('Kontaktart', sSubsetName) = 1);
SubsetDestroy('Kontaktart', sSubsetName);
EndIf;
if(SubsetExists('MA-Pool', sSubsetName) = 1);
SubsetDestroy('MA-Pool', sSubsetName);
EndIf;
SubsetCreatebyMDX(sSubsetName, '{TM1FILTERBYLEVEL({DESCENDANTS(Tag.['|NumberToString(pJahr)|']) }, 0)}');
SubsetCreatebyMDX(sSubsetName, '{TM1FILTERBYLEVEL({DESCENDANTS(Kontaktart.[Kontaktarten Gesamt]) }, 0)}');
SubsetCreatebyMDX(sSubsetName, '{TM1FILTERBYLEVEL({DESCENDANTS([MA-Pool].[MA-Pool Gesamt]) }, 0)}');
#count elements in subsets
numEl = SubsetGetSize('Tag', sSubsetName);
kontaktArtsize = Subsetgetsize('Kontaktart', sSubsetName);
maPoolSize = Subsetgetsize('MA-Pool', sSubsetName);
peSize = Subsetgetsize('Planungseinheit', 'Alle n Level');
dayi = 1;
kontaktArtIndex = 1;
maPoolIndex = 1;
peIndex = 1;
#Loop all elements in Subset
while(dayi<=numEl);
#get element name from index
sDay = SubSetGetElementName('Tag', sSubsetName,dayi);
while(kontaktArtIndex <= kontaktArtsize);
sKontaktArt = SubsetGetElementName('Kontaktart', sSubsetName, kontaktArtIndex);
while(maPoolIndex <= maPoolSize);
sMaPool = SubsetGetElementName('MA-Pool', sSubsetName, maPoolIndex);
while(peIndex <= peSize);
sPE = SubsetGetElementName('Planungseinheit', 'Alle n Level', peIndex);
nErlangMenge = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, sPE, sKontaktArt, 'ErlangC Menge Lmin');
nSonstigeMenge = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, sPE, sKontaktArt, 'sonstige Menge Lmin');
nBlendingMenge = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, sPE, sKontaktArt, 'blending Menge Lmin');
nMengeGesamt = nErlangMenge + nSonstigeMenge + nBlendingMenge;
nErlangRMA = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, 'Leistungsspektrum', sKontaktArt, 'Erlang rMA');
nNichtGeblendeteRMA = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, 'Leistungsspektrum', sKontaktArt, 'nicht geblendete rMA');
nNochNichtGeblendeteRMA = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, 'Leistungsspektrum', sKontaktArt, 'noch nicht geblendete rMA');
nRmaProdCap = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, 'Leistungsspektrum', sKontaktArt, 'noch nicht geblendete rMA');
nGesamtRMA = nErlangRMA + nNichtGeblendeteRMA + nNochNichtGeblendeteRMA;
prod = nMengeGesamt \ (nGesamtRMA * CellGetN('Blending_Simulation', sDay, pVersion, sMApool, sPE, sKontaktArt, 'Arbeitszeit in Min'));
ASCIIOUTPUT('C:\Testo.txt',NumberToString(dayi), NumberToString(peIndex), sPE,'Day: ', sDay, sKontaktart, sMaPool, sPE, NumberToString(prod), NumberToString(nProdCap), 'ErlangMenge', NumberToString(nErlangMenge), 'nSonstigeMenge', NumberToString(nSonstigeMenge),'nBlendingMenge', NumberToString(nBlendingMenge) );
While(prod > nProdCap);
ASCIIOUTPUT('C:\Testo.txt', NumberToString(prod), NumberToString(nProdCap));
nErlangRMA = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, sPE, sKontaktArt, 'Erlang rMA');
nNichtGeblendeteRMA = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, sPE, sKontaktArt, 'nicht geblendete rMA');
nNochNichtGeblendeteRMA = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, sPE, sKontaktArt, 'noch nicht geblendete rMA');
nRmaProdCap = CellGetN('Blending_Simulation', sDay, pVersion, sMApool, sPE, sKontaktArt, 'noch nicht geblendete rMA');
CellPutN(CellGetN('Blending_Simulation', sDay, pVersion, sMApool, sPE, sKontaktArt, 'rmA Prod Capping')+0.5,'Blending_Simulation', sDay, pVersion, sMApool, sPE, sKontaktArt, 'rmA Prod Capping');
end;
peIndex = peIndex +1;
end;
peIndex =1;
maPoolIndex = maPoolIndex +1;
end;
maPoolIndex = 1;
kontaktArtIndex = kontaktArtIndex +1;
end;
dayi=dayi+1;
end;
- Version: PAL 2.0.9.18
Please read the request for help guidelines:
https://www.tm1forum.com/viewtopic.php?f=3&t=1037
Many thanks.
Many thanks.
IBM Champion 2024
IBM Champion 2024
Normally, you would set the counter in the loop to the initial value (1 here) before the WHILE statement.
Consider also using a cube view as the data source of the process, instead of looping 3 times. This can be very inefficient (not necessarily so but oftentimes it is).
IBM Champion 2024
IBM Champion 2024
- orlando
Not the last time you will forget this.....
may be, but the code works - that is the most important thing.
now you can start with the optimization
Best regards
orlando
