Hello friends,
i'm stucking at adding an element to my own created Control Dimension.
I used a TI procress to create a control Dimension called "}Global Assumptions" now i want to add an element called "TodaysDate" so i try to add it with a small TI pro where i added in the Epilog
"DimensionElementInsert( pDimName, ' ', pElementName, pElementType );"
Where
pDimName = }Global Assumptions
pElementName = TodaysDate
pElementType = S
i get no error when i run the process but the element doent get added.
Someone know where my mistake is?
I want to add this to control dimensions to hide it from "Normal" users
THanks for your help
Add Elements to own Control Dimension
- OLAP Product: TM1 / TM1 Web / Perspectives
- Version: Planning Analytics V2.0.9
Re: Add Elements to own Control Dimension
Hello Again,
my fault, i can't read...
I put the code on the epilog but the docs says it can't be there...
"DimensionElementInsert adds an element to a dimension. You can use this function to add numeric, string, or consolidated elements. You can't use this function in the Data or Epilog procedures of a TurboIntegrator process."
- Version: PA 2.0.9.1
- Excel Version: 365
Check out DimensionElementInsertDirect
- paulsimon
- Version: PA 2.0.5
You have solved your own problem. Put the code in the Prolog or MetaData and it will work.
However, I would advise you against starting dimensions with }. It can become difficult to differentiate these from real Control Dimensions. You run the risk that IBM might use this dimension name at some point in the future.
Instead, start the dimension with a normal alphabetic character, possibly a prefix such as za_ to make them sort at the bottom. If you want to hide the dimension from users then just use DimensionSecurity and NONE.
Paul
Paul
