I have a little VBA project that integrates PPT and Perspectives, ...in short..., from a meny in PPT I open a Perspectives report, I filter it, and then refreshes it by using 'xlApp.Application.Run ("TM1REFRESH")'.
I now want to make this to work with PAX, but I run into a problem when refreshing the report. 'TM1REFRESH' is not available as Perspectives is not loaded, so I use the PAX API instead, in this case 'xlApp.COMAddIns("CognosOffice12.Connect").Object.AutomationServer.Application("COR", "1.1").RefreshSheet'. This works if I run the syntax from within VBA in Excel, but not from PPT, I get an error: 'Automation Server available only on STA'. Not yet sure what that means.
I have also tried 'xlApp.Run("ONKEY_ALT_F9")', i.e. keys Alt + F9, to refresh the sheet. It works, but it takes 10 times longer than a 'Rebuild Sheet'.
1: should I be able to use the PAX API to interact with Excel from 'outside' Excel, e.g. PPT?
2: is there another smart way to do this, e.g. standard Excel functionality, but that is as fast as PAX's 'Rebuild Sheet'?
PAX API: Refresh Sheet
- OLAP Product: TM1 / TM1 Web / Perspectives
- Version: Planning Analytics V2.0.9
Re: PAX API: Refresh Sheet
Whats happen if you make a VBA Public Sub in the Excel Workbook for refresh the TM1 Values like
then you cann call this routine from Powerpoint.
BR
Public Sub RefreshTM1Values()
Application.Run"TM1REFRESH" 'Or TM1RECALC
End Sub
BR
