Hi Experts,
I need to add a button in PAW to give the user the ability to run a process.
I saw it on IBM Cloud.
But I cannot see it in my environment and I am a Workspace and Tm1 administrator.
thanks
PAW Button does not give RUN Process option
- Version: 2.0
- Excel Version: EXCEL 2013
Micheline
Micheline
- Version: PAL 2.0.9.18
Re: PAW Button does not give RUN Process option
What version do you use ?
IBM Champion 2024
IBM Champion 2024
To add to Wim's point - the ability to run processes from buttons in Workspace only got added in PAW 39 which was released in March.
In earlier versions you will still need to add an action button to a websheet via PAX and then load that into your PAW book.
https://www.ibm.com/support/knowledgece ... s_paw.html
The ability to automatically refresh a book after completion of a process, rumored to be coming in PAW 44.
The ability to pass context of SUBNM selections to process parameters sometime beyond PAW 44.
In the meantime there's always TM1Web (or embedding TM1Web within PAW).
- Version: 2.0
THANK You all. YES, you are right. I am at version 36. Did not even occur to me to compare versions.
Thank you again.
Thank you again.
Micheline
Micheline
Certainly with PAW where versions change every couple of weeks.
IBM Champion 2024
IBM Champion 2024
