I would appreciate it if anyone could help me with this.
This are two cubes with same dimension elements and rules. Then only difference it is the name and some values of the elements in one dimension. But if you can see it the cube "Activo Fijo Tributario" does not working on consolidation elements for the element "Depreciation" and "AY" and in the cube called "Activo Fijo Financiero" it work fine and both have same rules (only with the order dimension and name changed).
This are the rules:
SKIPCHECK;
['Budget', 'January','LM']=
N:DB('CP_CB20_Activo_Fijo_Tributario','LM', !Centro Beneficio Cons,!Centro Costo,ATTRS('year',!year,'previousyear'),!Activo Fijo,!Version_Holding,DB('Calendar',!Version_Holding,'Budget Month','String'),!Moneda,!Sociedad,'Real')-1;
['Budget','depreciation','January']=N:if(['LM']<1,0,(['AY']/['LM']));
['Budget','depreciation']=N:if(['LM']<1,0,DB('CP_CB20_Activo_Fijo_Tributario',!Indicadores Activo Fijo,!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'January',!Moneda,!Sociedad,!Escenario));
['Budget','AY']=N:
DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,ATTRS('Month',!Month,'previousperiod'),!Moneda,!Sociedad,!Escenario)-
DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,ATTRS('Month',!Month,'previousperiod'),!Moneda,!Sociedad,!Escenario);
['Budget', 'LM']=N:if(DB('CP_CB20_Activo_Fijo_Tributario',!Indicadores Activo Fijo,!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,ATTRS('Month',!Month,'previousperiod'),!Moneda,!Sociedad,!Escenario)-1<0,0,
DB('CP_CB20_Activo_Fijo_Tributario',!Indicadores Activo Fijo,!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,ATTRS('Month',!Month,'previousperiod'),!Moneda,!Sociedad,!Escenario)-1);
FEEDERS;
['LM','Budget']=>DB('CP_CB20_Activo_Fijo_Tributario','LM',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,!Month,!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'February',!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'March',!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'April',!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'May',!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'June',!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'July',!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'August',!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'September',!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'October',!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'November',!Moneda,!Sociedad,'Budget');
['AY','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','AY',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'December',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'February',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'March',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'April',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'May',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'June',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'July',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'August',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'September',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'October',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'November',!Moneda,!Sociedad,'Budget');
['Depreciation','Budget','January']=>DB('CP_CB20_Activo_Fijo_Tributario','Depreciation',!Centro Beneficio Cons,!Centro Costo,!Year,!Activo Fijo,!Version_Holding,'December',!Moneda,!Sociedad,'Budget');
['Depreciation']=>['AY'];
['LM']=>['Depreciation'];
