- It reads from an Oracle database and loads a cube
- It processes the dataset through both the Metadata and Data tabs
- It clears the target cube
- CubeSetLogChanges is set to 0 prior to the ViewZeroOut
- It writes both numeric and string data to the cube
- Target cube has no rules/feeders
- It process the records and completes the Metadata procedure in approximately 1:20 minutes
- It processes the first 160549 records in the Data procedure at a rate just shy of 11,000 records per sec.
- Starting with record 160550, the processing speed drops to between 16 and 20 records per sec. Yeah.
- This behavior is repeatable.
- Dropped the Metadata procedure by removing its code
- Flipped the Use Unicode checkbox
- There were some CELLPUTS that were writing to a consolidation. Removed those.
- Removed all CELLPUTS statements.
- Used colorful metaphors. Used non-colorful metaphors. Talked bad about the process' mama.
"160547.000 200, Base, AAA-AAA-002, 01.XYZ.123456789.00, LOL-222-UCF, 435, Total Cost, 01.XYZ.123456789.00"
"160548.000 200, Base, AAA-AAA-002, 01.XYZ.123456789.00, LOL-222-UCF, 0, Total Base, 01.XYZ.123456789.00"
"160549.000 200, Base, FIG-100-BOP, 01.ABC.000000000.00, LOL-222-OHC, 460, Total Cost, 01.ABC.000000000.00"
"160550.000 200, Base, FIG-100-BOP, 01.ABC.000000000.00, LOL-222-OHC, 0, Total Base, 01.ABC.000000000.00"
"160551.000 200, Base, FIG-100-BOP, 01.ABC.987654321.00, LOL-222-OHC, 460, Total Cost, 01.ABC.987654321.00"
"160552.000 200, Base, FIG-100-BOP, 01.ABC.987654321.00, LOL-222-OHC, 0, Total Base, 01.ABC.987654321.00"
