REST API: consolidated elements without children
Dimix
Post by Dimix »
Sorry for a very basic (?) question, but this is still pretty new to me.
I'm looking for a way to list all consolidated elements within a dimension without any children.
Below syntax will retrieve all members (and number children) in the plan_business_unit dimension.
Dimensions('plan_business_unit')/Hierarchies('plan_business_unit')/Members?$expand=Children($select=Name), Element($select=Name,Type), Children/$count
I can then use Type to check for consolidated elements and number of children.
I'm sure there is an easier way to do this, i.e. only retrieve consolidated elements without any children. I have tried to combine above request with ?$filter=Level%20gt%200 and $count eq 0, but I can't get it to work.
Doable?
PavoGa
Excel Version: 2013 PAW
Re: REST API: consolidated elements without children
Post by PavoGa »
Example Dimension has two consolidations without children:
Test2 hierarchy.png (13.97 KiB) Viewed 6160 times
This MDX code produces as set of the consolidations without children:
FILTER(EXCEPT(TM1SUBSETALL( [test2] ), TM1FILTERBYLEVEL( TM1SUBSETALL( [test2]), 0)),
    TM1TUPLESIZE( ([test2].currentmember.children).ITEM(0)) = 0)
Save the subset and expose the subset with REST API.
Ty
Cleveland, TN
Pretty sure this would return the same.
FILTER(TM1FILTERBYLEVEL( TM1SUBSETALL( [test2]), 1), TM1TUPLESIZE( ([test2].currentmember.children).ITEM(0)) = 0)
Childless consolidations still evaluate as level 1 and not level 0.
MariusWirtz
Version: 10.2.2.6
Post by MariusWirtz »
This should do the trick:
/api/v1/Dimensions('plan_business_unit')/Hierarchies('plan_business_unit')/Members?$select=Name&$expand=Element($select=Type),Children/$count&$filter=Element/Type eq 3 and Children/$count eq 0
PavoGa
Post by PavoGa »
lotsaram wrote: Tue Mar 05, 2019 8:22 pm
Flat did not think about/realize that. Good tip, thanks.
Ty
Cleveland, TN
Version: PAL 2.0.9.18
Not sure I understand why you would not use easier functions that TM1TupleSize and Item. Straight from my MDX page:
Consolidations without children:
{Filter( TM1FilterByLevel( TM1SubsetAll([test]), 1), ISLEAF( [test].CurrentMember ))}
{Filter( TM1FilterByLevel( TM1SubsetAll([test]), 1), [test].CurrentMember.FirstChild.Name = "")}
{Filter( TM1FilterByLevel( TM1SubsetAll([test]), 1), Count([test].CurrentMember.Children) = 0)}
IBM Champion 2024
@Wim I'm kinda surprised that the first query works!
That I think would have to be a bug in the MDX engine or interpretation of what a "leaf" is (that is a numeric element). A consolidation without children can't store data. It isn't a leaf in any normal sense.
PavoGa
Post by PavoGa »
Wim Gielis wrote: Wed Mar 06, 2019 12:27 am Hi
@Wim, ask a hard question. :)
1) Have visited your MDX page. Just did not recall those queries or would have referenced them.
2) Have to admit I'm not as up on all the various MDX functions as you obviously are, but am grateful someone knows more me.
3) After wondering what TM1TupleSize's purpose for existence is, I have found a use or two. And now that I've got that hammer, all queries like this look like nails.
4) Great Granddaddy Butler was a Methodist circuit preacher and I got a bit of that in me I guess. I'm preaching the Gospel of TM1TupleSize.
Seriously, thanks. I am going to visit your MDX page again! Good :idea:
Ty
Cleveland, TN
PavoGa wrote: Wed Mar 06, 2019 12:16 pmSeriously, thanks. I am going to visit your MDX page again! Good :idea:
Thanks ! Happy reading.
IBM Champion 2024
