Location of the file accessible from the Cognos TM1 server
Posted: Mon Feb 11, 2019 11:54 pm
Hi gurus,
I'm new in the forum so hello to everyone.
Sorry if my question is too basic. I need to load data from .txt files into tm1 cubes with TI processes. I have 6 proccesses, 5 to update dimensions and 1 to load data. I need a process to call the 6 processes and then create a chore to automate the data load everyday.
My tm1 server is linux (ubuntu). When I choose a file as datasource in the process I get this warning.
The "Location of the file accessible from the Cognos TM1 server" field is not specified properly or the specified file can not be accessed from the TM1 server. For a process to run when scheduled as part of a chore, the file location must be accessible from the TM1 server. If you do not specify a proper file location, it will not be possible to schedule a refresh of the data using a chore.
I can open and run a process but when I use the process that call all the processes it fails.
The .txt files are locate in the windows client. Where is the proper file location?
I've tried to create a process with the file in the linux server and I can't see those files from the windows client.
Please tell me how can I use files with linux tm1 server and the windows client and create a chore with the processes.
Thanks in advance.
Thanks in advance.
