Auto Recalculate for Cube Viewer
macsir
OLAP Product: TM1, SSAS
Version: 9.5 - 10.2
Excel Version: 97 - 2013
Post by macsir » Tue Feb 05, 2019 5:34 am
Hi, all
I am just wondering if there is any hidden or undocumented function to enable Auto Recalculate for a Cube Viewer? So that when a user open a default view with that enabled already.
Similar to other functions, like ViewRowSuppressZeroesSet, ViewRowDimensionSet etc.
The reason is that all our cube views are rebuilt overnight using that group of functions based on definition in a centralized view management cube.
If it has, then it would be nice.
Version: PAL 2.0.6
Excel Version: 2016 - Office 365
Re: Auto Recalculate for Cube Viewer
Post by Wim Gielis » Tue Feb 05, 2019 11:23 am
I haven't found it and I would be happy to use it !
http://www.wimgielis.com ==> 107 TM1 articles and a lot of custom code
Newest blog article: Turbo Integrator: report on progress
kangkc
Version: 9.x
Excel Version: 200x
Post by kangkc » Tue Feb 12, 2019 4:41 am
Was bored with the long rule I am writing currently and decided to take a break and investigate this.
If you edit the .vue file directly, the auto-calc flag is at code 376. A value of "1" means auto-recalc.
Problem is public view won't work after you manually edit until a server restart. I presume you can write a external program to modify this flag while server is on schedule down time. Did some testing by changing this between restart and seems to be switching correctly from auto to manual recal.
389,100
390,"By Country auto"
370,0
361,1
362,1
363,0
364,0
365,
366,
367,0
376,1
375,b:0.#########G|0|
374,1
7,actvsbud
270,3
Variance
Actual
Budget
