MDX with Expand Above in Subset
kenship
OLAP Product: Cognos
Version: Planning Analytics 2.0.7
Post by kenship » Tue Jan 22, 2019 7:11 pm
I'm building a subset using MDX. The hierarchy structure looks like this:
Net Profit
> Gross Exp
> Exp Group
> GL Accounts
> Revenue
> Rev Group
> GL Accounts
The request is to list all of them to the lowest level but using Expand Above so that subtotal at the bottom, except Net Profit to remain on top.
When I use MDX and apply Expand Above, Net Profit will to the bottom, I use the Except statement to exclude it. But I have no luck putting Net Profit back to the top. No matter what MDX function I use to include Net Profit, it will show up at the bottom.
My question is: Is there any way to put Net Profit on top and keep the Expand Above layout.
Right now it looks like this, it won't show Net Profit at all.
EXCEPT(
{TM1DRILLDOWNMEMBER({[GL_Account].[NetProfit]},ALL,RECURSIVE)}
,{[GL_Account].[NetProfit]}
Thanks.
Kenneth
paulsimon
Version: PA 2.0.5
Re: MDX with Expand Above in Subset
Post by paulsimon » Tue Jan 22, 2019 9:00 pm
Hi Kenneth
The following should do it
{ UNION(
                { [GL_Account].[NetProfit]},
                { EXCEPT(
                                { TM1DRILLDOWNMEMBER( { [GL_Account].[NetProfit] } , ALL , RECURSIVE ) } ,
The Union just puts Net Profit at the top, since you aren't expanding it, expand above won't apply. Not actually tried it, but it should work. Let me know.
kenship
Post by kenship » Wed Jan 23, 2019 1:33 pm
Thanks but unfortunately it still put Net Profit down at bottom.
I began to believe that since the elements expanded are coming from the same parent (Net Profit) that I want to place on top, the Expand Above overrides and put it at bottom no matter what the MDX said.
Kenneth
Hi Kenneth
{ UNION(
                { EXCEPT(
paulsimon
Version: PA 2.0.5
Post by paulsimon » Wed Jan 23, 2019 10:00 pm
Hi Kenneth
I see the problem. To get around it I did the following on the SDATA sample cubes, using the account2 dimension which is the most similar one I could find on a sample cube that we can both access.
The solution needs two subsets.
Create a Subset called Subset Exp Above, which has the Expand Above option and the MDX Expression
{ EXCEPT( {TM1DRILLDOWNMEMBER( {[account2].[Earnings Before Taxes] }, ALL, RECURSIVE )}, { [account2].[Earnings Before Taxes] }) }
I then created a second subset with the Expand Above option turned off and the Expression
{UNION( {[account2].[Earnings Before Taxes] } , {[account2].[Subset Exp Above] } ) }
The second part of the union references the subset created above. It appears that this gets around the problem. Even though the containing subset does not have Expand Above turned on, the Expand Above set on the Unioned in Subset is retained.
Version: PAL 2.0.8
Post by Wim Gielis » Thu Jan 24, 2019 7:51 am
That's a good trick Paul !
http://www.wimgielis.com ==> 109 TM1 articles and a lot of custom code
Newest blog article: Set up a TM1 model with AutoHotKey as a service or application
kenship
Post by kenship » Thu Jan 24, 2019 3:18 pm
Agree! It's a good solution.
Thanks Paul!
