MDX filter on Customer dimension (11-20th member) based on revenue (measurements dimension)
cecilia.andersson3
Version: Planning Analytics
Post by cecilia.andersson3 » Tue May 22, 2018 8:32 am
I am trying to create an MDX filter on the "Customer" dimension based on revenue ("Measurements" dimension) for the 11-20th members.
I have 1 cube with 11 dimensions, which includes the Customer and Measurements dimensions.
I have found these two filters, which I believe I could use but I just don't know how to combine them. Any ideas?
{Subset ( {TM1FilterByLevel(TM1SubsetAll ( [Kund] ) , 2)}, 11, 10)}
{FILTER({TM1FILTERBYLEVEL( {TM1SUBSETALL( [Product] )}, 0)},
[Test].([Posting Measures].[Amount]) > 0 )}
Appreciate any guidance! Many thanks!
Version: PAL 2.0.6
Excel Version: 2016 - Office 365
Re: MDX filter on Customer dimension (11-20th member) based on revenue (measurements dimension)
Post by Wim Gielis » Tue May 22, 2018 8:54 am
For example,
{FILTER({Subset ( {TM1FilterByLevel(TM1SubsetAll ( [Kund] ) , 2)}, 11, 10)}, [Test].([Posting Measures].[Amount]) > 0 )}
and you will want to restrict the selection in the Test cube more such as to come to the desired results. Select in the cube on year, period, scenario, ...
http://www.wimgielis.com ==> 108 TM1 articles and a lot of custom code
Newest blog article: Access to cube cells in TM1
Post by David Usherwood » Tue May 22, 2018 8:57 am
EXCEPT should do what you want
http://www.mdxpert.com/Functions/MDXFunction.aspx?f=113
ie (pseudo-code)
except([Top20],[Top10])
