Setting an Alias on Title dimension in a view
PeteB
OLAP Product: Planning Analytics Local, PAW
Version: PAL 2.0.6, PAW 2.0.45
Post by PeteB » Thu Dec 08, 2016 11:44 pm
Is there a way to attach an alias to the title dimension in a view.
I am currently using the following commands to set the element for the title dimension, however I can't find the command to turn on the alias for the dimension.
ViewTitleDimensionSet( sCube, sView, sDim );
ViewTitleElementSet( sCube, sView, sDim, nIndex );
Version: PA2.0.6 Classic(PAW-free zone)
Excel Version: 2010 and Office 365
Re: Setting an Alias on Title dimension in a view
Post by Alan Kirk » Fri Dec 09, 2016 12:00 am
PeteB wrote:Hi,
Off the top of my head the only way I can think of to do this is to create a subset for the dimension in question (use MDX if you want it to dynamically update, or Bedrock has a few good functions for quick'n'easy subset creation), assign it with ViewSubsetAssign, then you can use SubsetAliasSet. The rest is as you're doing it at the moment.
PeteB
Post by PeteB » Fri Dec 09, 2016 5:24 am
Yes that will work
