Guys,
I came across an interesting one today. I tried to use the above function in TI to set the Alias for the Default Subest of a dimension. The process was also updating the default dimension. After running the process the subset looked good but the alias was nto switched on. I tried moving the set alias to a seperate process this didn't work. I then noticed that I had a private default subset. Upon deleting the said private subset the process worked. It looks like TM1 got confused trying to set the alias when you have a private and public subset of teh same name,
Jim.
SubsetAliasSet
- jim wood
- Version: PA 2.0.7
SubsetAliasSet
Shop at Amazon
Shop at Amazon
