TM1 Upgrade issues
tomago
- Version: 10.2.1.2
- Excel Version: 2013
TM1 Upgrade issues
Hi we are currently running TM1 9.1 SP3 (32bit), Production -TM1, Development - SData
We are trying to upgrade to TM1 9.4 and having some issues.
Installation is succcessfull, but the new tm1 Pdata doesn't start. I delete the service, and recreate pointing to cfg file. this starts the service, and i see the tm1server log generate comments.
at the end of startup i am left with this
124 INFO 2012-02-09 23:08:04,795 TM1.Server TM1 Server is ready
I used to see in the other logs it would mention, notifying admin server. Is that the older version or do i have a problem?
When i try and connect to server via client, here is the error - Cannot connect to TM1 Admin Server
Please help
Please help
Re: TM1 Upgrade issues
I can't recall what 9.4 wrote into the logs. (And if you're going through the pain of an upgrade anyway, I'd suggest 9.5.2 since it'll give you a longer support window, but I digress.)tomago wrote:Hi we are currently running TM1 9.1 SP3 (32bit), Production -TM1, Development - SData
However here are some random thoughts:
- Is the Admin Server actually running?
- More to the point, is it running on the server that you have specified in the AdminHost parameter of your TM1S.cfg file?
- What are the port numbers of the various services that you have running?
- Is there any chance that you have duplicated port numbers somewhere?
- Is your client software specifying the correct Admin Host?
I'd start by checking the answers to all of those questions.
tomago
- Version: 10.2.1.2
we don't want to go straight to 9.5.2 as it is the newest and still some bugs around.Alan Kirk wrote:I can't recall what 9.4 wrote into the logs. (And if you're going through the pain of an upgrade anyway, I'd suggest 9.5.2 since it'll give you a longer support window, but I digress.)tomago wrote:Hi we are currently running TM1 9.1 SP3 (32bit), Production -TM1, Development - SData
Admin server is running, Services show that
AdminHost is set correctly
Port number is 12345 - this is configured for production and development
client software is pointing to new host yes.
both production and development have no issues
Not any more it ain't.tomago wrote:we don't want to go straight to 9.5.2 as it is the newestAlan Kirk wrote:I can't recall what 9.4 wrote into the logs. (And if you're going through the pain of an upgrade anyway, I'd suggest 9.5.2 since it'll give you a longer support window, but I digress.)tomago wrote:Hi we are currently running TM1 9.1 SP3 (32bit), Production -TM1, Development - SData
And you think that 9.4 doesn't???tomago wrote:and still some bugs around.
Also any bugs that you encounter in 9.4 will now be met with a single sentence from IBM Support.
"Upgrade to 10.1".
You say that "Port number is 12345 - this is configured for production and development". If that's the case then they can't be running using the same Admin Server. If you have two sessions which have the same port number on the same Admin host, one of 'em ain't gonna work. Which raises the question of what the pData service's port number is, and which admin server / admin host it's pointing to. You can't use 12345 for everything.tomago wrote:Admin server is running, Services show that
tomago
- Version: 10.2.1.2
we have production server running tm1
we have development server running sdata
and 3rd server running pdata
3 different machines running their own instance, so no issues with conflicting ports.
And you're certain that the tm1s.cfg file for pData is pointing to the Admin Server on its own machine, not to one of the others?tomago wrote:we have production server running tm1
Are you pointing the client's Admin Host to ONLY the pData server, or do you have it pointing to multiple Admin Hosts?
Have you tried proxying on to the pData server and trying to connect from there?
Also, if you have the Admin Host specified as the machine name in the client, have you tried using the IP address instead? (Or, less likely, vice versa though I recall someone mentioning that had worked for them before.)Alan Kirk wrote:And you're certain that the tm1s.cfg file for pData is pointing to the Admin Server on its own machine, not to one of the others?tomago wrote:we have production server running tm1
tomago
- Version: 10.2.1.2
Hey Alan
Here is the config file
[TM1S]
ServerName=pdata
SecurityPackageName=Kerberos
#SecurityPackageName=NTLM
IntegratedSecurityMode=2
PasswordSource=LDAP
#LDAPUseServerAccount=T
UseSSL=T
DataBaseDirectory="D:\Tm1s7\TomagoData"
LoggingDirectory="D:\Tm1s7\TomagoData log"
AllowSeparateNandCRules=T
AdminHost=TACBUD04
PortNumber=12345
Protocol=TCP
MaximumLoginAttempts=10
LDAPPort=636
LDAPHost=domain.com.au
LDAPWellKnownUserName="cn=Tm1service,ou=Service-Accounts,ou=All-Users,dc=domain,dc=com,dc=au"
LDAPWellKnownPassword=applix04
LDAPSearchBase="ou=All-Users,dc=domain,dc=com,dc=au"
LDAPSearchField=sAMAccountName
if the cfg file is wrong, the service doesn't start, and it starts fine.
what do you mean proxy onto the pdata server, try using the client from the server to connect to its pdata?
tried that same problems
are there any tests i can try to find errors?
[TM1S]
ServerName=pdata
PasswordSource=LDAP
UseSSL=T
AdminHost=TACBUD04
PortNumber=12345
Protocol=TCP
LDAPPort=636
Gregor Koch
- Version: 9.0 and up
- Excel Version: 2007 and up
Is pdata running on TACBUD04?tomago wrote: ServerName=pdata
AdminHost=TACBUD04
PortNumber=12345
Does any of you other cfg files the same Adminhost and Portnumber like the one you have posted?
Really? You can easily have typos in cfg files, which means the setting will not be changed, and the server will still start fine. So how do you define "wrong" in that context?tomago wrote: if the cfg file is wrong, the service doesn't start, and it starts fine.
Uhm, are you asking what that means?tomago wrote: what do you mean proxy onto the pdata server, try using the client from the server to connect to its pdata?
proxy onto the pdata server = remote desktop to the machine which is running the pdata TM1 server.
Or have you tried it already?
Have you actually tried not to use port 12345 (some firewalls are not very friendly with this one).
Best you post the other cfg settings so they can be compared.
tomago
- Version: 10.2.1.2
rather than continue this route with the first road block being the version, i have upgraded to 9.5.2
Installed on the server, default settings.
services running, and log tells me
1356 [] INFO 2012-02-10 02:27:10.812 TM1.Server Notifying the Admin server
Try and connect from the server client to the servers instance of default Sdata and no luck
I have looked into the etldap side of things, as i am checking to make sure this is ok. when i check the TM1 Login test
80: SystemServerClientNotFound
tomago
- Version: 10.2.1.2
more information
i have the client on my machine, and when trying to connect, i was getting - Cannot connect to TM1 Admin Server
I have gone through errors found and ini files etc and managed to resolve this. ended up being an SSL error to do with the old applix location, couldn't find applixca.pem
anyways, now i click connect, get to the Connect to TM1 Server box
select my server ID - sdata
enter my AD credentials, and error is
N6) Client not registered
