Grand Parent 1
-- Parent 2
--- Child 3
--- Child 4
--- Child 5
-- Parent 7
-- Parent 8
How can i create a while loop that when i specify Grand parent 1 element, it will return all the level 0 element which is Child 3, 4 , 5 , Parent 7 an 8? or when i specify Parent 2, it will return Child 3,4 and 5.
Getting level 0 element
- Version: 9.0 and up
- Excel Version: 2007 and up
Re: Getting level 0 element
A 'while loop' in Turbo Integrator? How many levels are in the hierarchy?
Have you considered the ELISANC function?
- Alan Kirk
Can you please clarify your question? In the title you're talking about "Getting Level 0 element". In the body of it you're saying that you want consolidations (which are not level 0 elements) returned as well ("Parent 7 an 8"). Which is it? The answer will be quite different depending on what your real intention is.winsonlee wrote:Grand Parent 1
-- Parent 2
--- Child 3
--- Child 4
--- Child 5
-- Parent 7
-- Parent 8
However in either case, you may want to look at the ElComp, ElCompN and ElIsAnc functions to see whether they point you in the right direction.
- Version: 9.5
thanks for the tips..
got it working ...
[code1]
i = DIMSIZ(DimOrder) ;
WHILE( i > 0) ;
vElem =DimNM (DimOrder, i);
vLevel = Ellev (DimOrder, vElem);
vParent = ELISANC(DimOrder, Customer, vElem);
IF (vParent = 1 & vLevel = 0);
SubsetElementInsert(DimOrder, subOrder, vElem,1);
ENDIF;
i = i -1 ;
END;
[/code]
got it working ...
[code1]
WHILE( i > 0) ;
ENDIF;
i = i -1 ;
END;
[/code]
- Version: 9.5
parent 7 & 8 does not have any element under them, so it is still consider as Level 0 element.
