TM1 crashes when saving rule
andre lie
Post by andre lie »
I experience TM1 crashing when saving rule on several og my cubes. When i view from tm1top, seems TM1 has recahed commit stage but then crashes.
Visual debugger appears then shows error: 'memory could not be written at reference....', server out of memory.
But before saving rule, i notice from windows task manager my server still have available memory. I am working on 9.1 SP3, 4 GB RAM, 8 cores processor. I try using old and new rule editor with same result
However, if i edit the rule from notepad, then restart the server, the rule can be loaded properly (without running out of memory). For time being, if anything to change on those rules, i have to do it from notepad and restart the server, which is really silly
Anyone has idea how to overcome this or this is software bug?
Andre
mattgoff
Version: 10.2.2.6
Excel Version: O365
Re: TM1 crashes when saving rule
Post by mattgoff »
What version of TM1 are you running: x86 or x64? If x86, have you enabled the /3gb swtich in boot.ini? If not, TM1 can only use up to 2GB of system RAM. I assume that TM1 uses some additional memory during the commit process that's not necessary when computing from scratch.
Matt
andre lie
Post by andre lie »
I am running x86 9.1 SP3
I don't think I have enabled the /3gb switch in boot.ini. Can you provide the line statement to enable it? Where is the file normally located?
Andre
mattgoff
Version: 10.2.2.6
Excel Version: O365
Post by mattgoff »
andre lie
Post by andre lie »
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows Server 2003, Enterprise" /noexecute=optout /fastdetect /3GB
Right Click my computer, choose properties, advance tab, settings under startup and recovery and then edit. Add the /3GB and save. Restart the server
I have tried saving one of the rules that normally causes the server down. This time, it completes sucessfully
Rgds
Andre
ScottW
OLAP Product: TM1 CX
Excel Version: 2003 2007
Post by ScottW »
Hi Andre,
The 3Gb switch buys you some breathing space but you should also have a look at why your rules are consuming so much memory.
Try using TM1'sbuilt in PerfMon cubes, the relevant one will be }StatsByCube to see which cubes are using the most memory, and whether memory usage is due to data or feeders.
If it turns out there isn't anything you can do to rewrite the application to be more efficient then ultimately you will need to consider x64. However you will usually find that a lot of memory can be saved by making sure rule and feeder statements have tight and matching area statements.
Scott W
Cubewise
www.cubewise.com
