In an active form I'm using an action button with process call. The process has several parameters. When saving and reopening the active form, all parameters are merged in one "Name" field and values also. Is this a known issue?
Thanks in advance for any hint!
I'm using 9.5.1 /Excel 2007
Parameter error in Active form
- Version: 2.5 to PA
- Excel Version: Lots
Re: Parameter error in Active form
I have seen that before, but I had been switching the worksheet with the Action Button back and forth between different versions of TM1, so put it down to that. I think I just recreated the button and it sorted itself out.
Andy Key
- OLAP Product: TM1, COGNOS
- Version: TM1 9_5 Cognos Planning 8_4
Any solution? I am using TM1 10.2 & Excel 2013 32 bit on 64bit OS.
Still the action button parameters are merging up.
Another issue is: The excel file on perspective is kept on formula auto calc & is updated on web (tm1 10.2 web) but whenever it is sliced or opened from perspective application folder the excel file (report) is automatically set to formula - manual.
