I am using Visual Studio 2008 (framework 3.5) and TM1 9.5.1. TM1 9.5.1 is not installed on the client that I am working on (as our current live version is 9.0) , but I do have a copy of the 9.5.1 bin folder, taken off a test machine
The following code runs without errors:
Dim objHostServer As TM1AdminServer
Dim objServerCollection As TM1ServerInfoCollection
Dim objServer As TM1Server
' connect to the server and retrieve a list of models
objHostServer = New TM1AdminServer(strServer, strSSL)
objServerCollection = objHostServer.Servers
For Each objServer In objServerCollection
MsgBox(objServer.Name)
Next
Could anybody point me towards a likely cause of the problem, as currently I am looking in the following areas for possible causes and am likely to change things that don't need changing
- admin server config file
server config files
SSL certificates
