Using TM1Web 9.4 on test server 64bit (vmware)
Zooming: When zooming out on Excel reports with frozen panes, the frozen panes (columns and rows) show only white space where the extra viewable area should be. The areas not frozen display correctly.
Exporting: When exporting to Excel or PDFs the columns containing report titles expand to the width the of the title. For example, if you have Jan,Feb,Mar...data in columns below the title, the month with the title in the same column will resize when exported. Cognos support said the only workaround they have seen for this was to use a bitmap image for the title instead.
A fix for these issues is expected to be released in January.
11-81653841 TM1Web 9.4 Zooming and Exporting
- Version: 9.4
- Excel Version: 2003
Kerry Pollock
IBM Certified Devoloper - Cognos TM1
