Guys,
When creating wide reports in answers you can hit a maximum page width. When doing this you are not able to change the width of columns in pivot tables. I'm not sure at this point in time if you can change a setting to get around this. There is however a work around. You can change the left and right padding. This can be a problem if you get a large value in the field but it's the only way round it that I have found so far,
Jim.
Page Width
- jim wood
- Version: PA 2.0.7
Page Width
