Compare Sandbox in TM1 9.5
- OLAP Product: Cognos
- Version: TM1
- Excel Version: 2003
How to show compare sandbox between sandbox in TM1 Contributor on a single page. It's possible?
- rkaif
- Version: 9.1 or later
Re: Compare Sandbox in TM1 9.5
According to the Manual you can only work on one sand box at a time
Cheers!
Rizwan Kaif
Rizwan Kaif
You can write a TI that transforms a sandbox to a dimension and use this as a dimension in another cube. A TI will need to move data from the source cube to the target cube. GETACTIVESANDBOX() and USEACTIVESANDBOX() functions in the TI API need to be used.
- OLAP Product: oracle
- Version: 9.5
@ Rizwan:rkaif wrote:According to the Manual you can only work on one sand box at a time
Could you please explain where is this written in the manual ? I am new to the TM1 and have directly started with 9.5! I have been going through the User's Guide, where it is mentioned in Chapter 3 (pg 36) that "You can name the sandbox and manage multiple sandboxes when the 'capability sandbox' is ON.
So, what does this stmt mean??
Sorry if I'm bothering you.. I'm entirely new to this, and would like to learn more on it!
Cheerz
- Steve Vincent
- Version: 10.2.2 FP1
go a bit further down in the guide, p.39 onwards "Using a Personal Workspace or Sandboxes" explains how they work.
