PAW License
Paul-TM1
PAW License
Post by Paul-TM1 »
This must have been answered long ago..
PAW - to me looks like any other reporting tool (interface to TM1 data, with ways to plan, create, and analyze content). I do not understand what justifies an admin license. Can someone please enlighten me?
Paul.
macsir
Version: PAL 2.0.9
Re: PAW License
Post by macsir »
An admin license is still required if you want to modify objects or other admin tasks through PAW.
Re: PAW License
An admin licence is not required to consume or create PAW content but a PAW licence is.
The admin licence is required for development and maintenance / admin functionality, but this should not require additional admin licences.
Where the confusion may arise is that admin licence people do not require a PAW licence, admins get to use PAW for free since this is where all the admin is done now.
Paul-TM1
Re: PAW License
Post by Paul-TM1 »
Thanks Steve and Macsir.
So to use PAW, admin license is not required, but to work on PAW's admin utilities, Admin license is required.
Is PAW License separate?
Paul.
Re: PAW License
Correct
It depends on the exact nature of your existing arrangement, if you have upgraded from the 10 series then it is probably additional.
If your first purchase was in the PA 2 series then it is probably included.
You need to check with whoever you bought your licence from.
luizg2019
OLAP Product: TM1 - PAX-PAW-Perspectiv-Arc
Version: PA 2.0.9 - PAW 2.0.73
Excel Version: office 2016
Re: PAW License
Post by luizg2019 »
Steve Rowe wrote: Thu Sep 10, 2020 12:31 pm
Correct
Do you know where in the documents, ibm support/fix central or contract we can find if we have PAW licenses?
burnstripe
Version: 2.0.9
Re: PAW License
Post by burnstripe »
It's always worth checking with your IBM representative your licence capabilities but licence documentation may be found here
https://www-40.ibm.com/software/sla/sladb.nsf/search/
My experience though (Disclaimer: not to be taken for granted) is generally if the licence has Planning Analytics in the name, so IBM Planning Analytics User, IBM Planning Analytics Explorer, IBM Planning Analytics Modeler, those users may use PAW in varying capacities.
If you have the old Cognos Express licences such as Performance Management users then only your Admin users can use PAW. The other users such as Performance Management users would require a PAW Add-on licence to use PAW. Your Performance Management users may however you PAX, the excel plugin.
luizg2019
Re: PAW License
Post by luizg2019 »
burnstripe wrote: Mon Jul 04, 2022 5:49 pm It's always worth checking with your IBM representative your licence capabilities but licence documentation may be found here
Thanks for the explanation!
I just found out our licenses are "IBM Cognos Performance Management Advanced Authorized User" so I guess our end users can continue using only PAX and no PAW. :(
burnstripe
Version: 2.0.9
Re: PAW License
Yes unfortunately no paw for end users. There is an add-on licence that can be acquired to give those performance management users access to paw
Those users will be good to use Pax and any of the legacy Web interfaces such as TM1Web (aka planning analytics spreadsheet services) and tm1 applications (pmpsvc)
