I couldn't quite see a definitive answer online for this,
After testing here is my understanding of security assignments:
At Cell Level Security you can only apply None, Read and Write but not Locked and Reserve.
Locked and Reserve can only be applied at element or cube level security.
Is the above correct?
Maren
Security Assignments
- OLAP Product: TM1 - PAX-PAW-Perspectiv-Arc
- Version: PA 2.0.9 - PAW 2.0.73
- Excel Version: office 2016
Re: Security Assignments
Although in the IBM documentation says you can use Lock and Reserved in a cell level, when I tried using those values in a CellSecurity cube, nothing seemed to change. The only values that worked were Read, Write and None. So I guess you're right.
