Good day
Environment:
planning analytics version 2.0.6 running on windows server 2016
PAW version 2.0.39 running on Red hat 7.5
Problem:
We have run into an issue recently in which when our TI processes are kicked off from PAW, we insert the necessary parameters and get notified that the process ran successfully, however the data that it was meant to be populate is missing. If we run the same TI process with the same tm1 user account from perspectives the process executed correctly and the data is populated.
Could this be some sort of security issue, or is this a known bug?
Any help would be greatly appreciated.
Running TI's from PAW doesnt execute correctly
- Version: PA 2.0.9.1
- Excel Version: 365
Re: Running TI's from PAW doesnt execute correctly
I'd think you could test the security issue by logging onto PAW as admin and determining if the process runs correctly then or not.
Was the process created in PAW or Perspectives? What is the datasource for the process?
