Dynamic Subset
lax9
Dynamic Subset
Post by lax9 »
Getting the below error while running TI:
Error: Epilog procedure line (412): Could not create dynamic subset:
expression:
{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( {[Account PCR].[DLR_REC_NACD2 DEALER RECEIVABLES - NACD (Cat Sales Inc) on LM Books] }, ALL, RECURSIVE ) },0 )}
Please let me know how to resolve this?
Thank you!
Edward Stuart
Version: All
Excel Version: All
Re: Dynamic Subset
Post by Edward Stuart »
What happens when you input the MDX into an expression window and run it manually?
Version: PAL 2.0.9.18
Re: Dynamic Subset
For me it works when I change the dimension name and the (consolidated) element name.
As Edward asked for, what happens if you do this in the Subset Editor of the dimension 'Account PCR' ?
Does the consolidated element have level 0 descendants ? Related to this, what happens if you use the undocumented argument in the function 'SubsetCreateByMDX' whereby adding the dimension name allows the subset to be empty ?
If all of this does not work, please provide a screenshot of this Subset Editor with the expression, where the dimension name and element name are clearly visible.
IBM Champion 2024
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Re: Dynamic Subset
Post by Mark RMBC »
I would say the problem is with the naming of the element, the parentheses in the name, i.e. (Cat Sales Inc) are causing the mdx to break.
Can you try the following and see if it works:
{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( {StrToMember("[Account PCR].[DLR_REC_NACD2 DEALER RECEIVABLES - NACD (Cat Sales Inc) on LM Books]") }, ALL, RECURSIVE ) },0 )}
cheers, Mark
Re: Dynamic Subset
Mark RMBC wrote: Wed Jul 18, 2018 9:15 am I would say the problem is with the naming of the element, the parentheses in the name, i.e. (Cat Sales Inc) are causing the mdx to break.
cheers, Mark
Hi Mark,
In PA 2.0.5 I cannot reproduce it. It works as expected.
IBM Champion 2024
Mark RMBC
Version: 10.1.1
Re: Dynamic Subset
Post by Mark RMBC »
Hi Wim,
in 10.1 I was getting an empty subset, but when I used StrtoMember or used the original mdx but without the name containing parentheses it returned the correct elements. I say was because I just tested it again and now it appears to be working!
I might be going mad!
