Error while adding new user group in Performance Modeler
buddha
Post by buddha »
Hope you are doing good.
Wondering if anyone has faced this situation. Getting following error while adding user group in Performance Modeler(attached screenshot). Was able to add groups from Architect though, trying to figure out whats the issue.
Internal Application Problem
There was an internal application problem. Try to save your work and exit the application.
'com.ibm.cognos.tm1.TM1Exception: ObjectAliasNotUnique'
WHILE [CCLMsg: system text='Exception adding new CAM Group']
com.cognos.pmta.api.exceptions.PMTAException.mapException(PMTAException.java:161)
com.cognos.pmta.api.modelmanagement.model.property.TM1ObjectProperties.setPropertyValue(TM1ObjectProperties.java:62)
com.cognos.pmta.api.modelmanagement.model.property.TM1ObjectProperties.setPropertyValues(TM1ObjectProperties.java:41)
com.cognos.pmta.api.modelmanagement.model.property.TM1DimensionMemberPropertySource.setPropertyValuesImpl(TM1DimensionMemberPropertySource.java:62)
com.cognos.planning.common.model.dimension.MemberPropertySource.setPropertyValue(MemberPropertySource.java:42)
com.cognos.planning.common.model.dimension.MemberRead.setPropertyValueInternal(MemberRead.java:176)
com.cognos.planning.common.model.dimension.MemberRead.setPropertyValue(MemberRead.java:163)
com.cognos.planning.common.model.dimension.MemberEditProxy.setPropertyValue(MemberEditProxy.java:25)
com.ibm.cdf.pmmodel.modellingOperations.dimension.SetMemberPropertyOperation.modifyDimensionImpl(SetMemberPropertyOperation.java:71)
com.ibm.cdf.pmmodel.modellingOperations.dimension.DimensionOperation.modifyDimension(DimensionOperation.java:90)
com.ibm.cdf.pmmodel.state.DimensionState.modify(DimensionState.java:227)
com.ibm.mdt.widgets.cube.actions.AddGroupAction.run(AddGroupAction.java:150)
com.ibm.cdf.cui.utilities.popup.CDFBaseMenuItem.runAction(CDFBaseMenuItem.java:661)
com.ibm.cdf.cui.utilities.popup.CDFBaseMenuItem.mouseUp(CDFBaseMenuItem.java:683)
com.ibm.cdf.cui.utilities.popup.CDFBaseMenuItem$2.handleEvent(CDFBaseMenuItem.java:141)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
com.ibm.mdt.app.Application.start(Application.java:85)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:88)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
java.lang.reflect.Method.invoke(Method.java:618)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Generated at 2018-05-23 15:36:32
Error Message.png (156.52 KiB) Viewed 3388 times
