PA: Multiple web instance
orlando
Version: PAL 2.0.8
Post by orlando »
with TM1 10.2 it was very easy to create a second TM web instance (copy the war rename it, tomcat extract the war, make settings, restart tomcat- done).
With Planning Analytics and webphere this doesn't work.
Even Copy the TM1Web Folder in WebApps,rename and restart does not work.
Does anaybody has an idea/link/approach how to set up a second or third web instance with planning analytics?
orlando
Re: PA: Multiple web instance
Good question. Especially when it comes to load balancing or failover of larger applications. No doubt it is "easy" if you happen to be a websphere expert. But then most of us aren't!
daniel.havassy
OLAP Product: Planning Analytics Local
Version: 2.0.4
Post by daniel.havassy »
the following has worked for me:
There is a Websphere related config file that you need to locate and amend with the designated parameters.
TM1_installation_location\tm1_64\wlp\usr\servers\tm1\server.xml
Within the xml file, edit the application node (duplicate it for each tm1web instance and change the property values). For example if you've had a separate tm1web instance for a regional application it could look like this:
<application id="apac" location="${wlp.user.dir}/../../webapps/apac" name="apac" type="war" context-root="apac"/>
Let me know if it helps.
orlando
Version: PAL 2.0.8
Post by orlando »
daniel.havassy wrote: Wed May 23, 2018 11:28 am Hi,
hi daniel,
thanks a lot. I will try it on friday (hopefully as a good start into the weekend) and let you know how it worked.
best regards
orlando
orlando
Version: PAL 2.0.8
Post by orlando »
Hi Daniel,
this is working perfect. Thanks a lot!
orlando
macsir
Version: PAL 2.0.9
Post by macsir »
Just out of curiosity, what is the general use to have multiple web instance?
orlando
Version: PAL 2.0.8
Post by orlando »
macsir wrote: Fri Jun 01, 2018 4:10 am Just out of curiosity, what is the general use to have multiple web instance?
i like to have one instance just for me for testing, playing etc...
it's more easy for the user to get one or two links without a drop down list to choose the tm1 database from (because they can't remeber the name)
JamiseBondi
Version: 2.0
Post by JamiseBondi »
orlando wrote: Tue May 22, 2018 12:49 pm Hello,
orlando
Hi Orlando,
This is a great idea and I'd really like to know more about the actual changes you made when you say "tomcat extract the war, make settings....". Could you please elaborate/explain what steps you took to get this working? We have multiple instances running through a single web process (tm1web) and I'd like to split it out so that we have a separate web process for each instance.
What I did as a minimum is to copy the "tm1web" folder (located under ...IBM\cognos\tm1_64\webapps) and renamed it to "tm1webtest1". Then edited the tm1web_config.xml file within the configuration folder as well as the common server.xml file per Daniel's suggestion and I can now browse a particular instance "test1" using a unique URL: http://appserver.domain.com:9510/tm1webtest1/
This much works, but even if I did this for instances from test 1 to test5 and navigated to all 5 instances using different URL's, when I look at the task manager on the web server, I still see a single java.exe process that I assume is responsible for serving all the web requests. I'd like to have a separate java process for each web process.... why? Because when a workbook crashes the web in one instance, it doesn't affect the other web sessions/instances/users.
orlando
Version: PAL 2.0.8
Post by orlando »
JamiseBondi wrote: Wed Jan 30, 2019 8:51 am
Hi JB,
in that case you need a second (third, fourth,fifth...) installation of websphere (or tomcat - when older TM1). One installation alway runs with one process (so my understanding).
I have never done that, but i think with a little research it is possible.
orlando
