Hi Experts, what are TM1 Rules Capabilities? Can it create cubes, dimension, other TM1 Objects etc. like the TI Process? I believe the answer is 'No' and that TM1 Rules are used majorly to calculate real-time numbers rather than storing numbers as a static value.
Thank You
What are TM1 Rules Capabilities?
- Version: TM1 Perspectives 10
- Excel Version: Excel 2016
- Version: PAL 2.0.9.18
Re: What are TM1 Rules Capabilities?
Indeed, rules are like Excel formulas, to calculate certain areas in a cube in a dynamic way (i.e. calculation on the fly with every refresh).
IBM Champion 2024
IBM Champion 2024
Thanks for confirming that Wim! Appreciate your help.
- Version: PA 2.0.9.1
- Excel Version: 365
TM1 reference guide is a good place to start.
https://www.ibm.com/support/knowledgece ... 80006.html
Thank you for reference link. Very helpful.
- Version: PAW 2.0.8
- Excel Version: 2019
And for most complex part, that is Feeders, please read this document:
https://www.ibm.com/developerworks/data ... ge620.html Thanks
Thank you BariAbdul!
