I am getting an error when I am trying to run tm1runti.exe from a Server with a Product Version of 10.2.20700.44 to connect to TM1 Product Version 11.1.00000.30.
The error is a generic error one below
(TM1 API Error) SystemServerNotFound
Server connection failed
However when I run same tm1runti command on the Server where TM1 11.1.00000.30 is installed that works successfully.
I have set the to ClientVersionMinimum=102 for the instance of TM1 11.1.00000.30 but still no luck.
Both the servers are on on-premise and I can ping the instance where TM1 11.1.00000.30 is installed.
Any feedback would be appreciated.
Cheerio
tm1runti on Planning Analytics
- OLAP Product: TM1 9x, BPC, Hyperion, HANA
- Version: TM1 10
- Excel Version: Excel 2003 - 2010
- macsir
- Version: PAL 2.0.9
Re: tm1runti on Planning Analytics
Basically, clients in each major version change won't be compatible. You can have tm1runti from version 11 to let it work.
