Hi Gurus,
I am stumped on a simple if condition which fails miserably. I am reading data from a csv file.
The first condition to check for blank works and fails checking 'N/A', <>0 and ='N'.
Can someone tell me where I am going wrong?
the condition translates to
if Proj_code is not blank or proj_code is not equal to 'N/A' or Proj_code is not equal '0' or if NewBuss is equal to 'N'
if ( Proj_code @<> '' % Proj_code @<> 'N/A' % Proj_code @<> '0' % NewBuss @= 'N') ;
EndIf;
I have verified that the data is 'N/A', '0'. Dont understand why the OR condition fails. Can someone please help?
Paul.
Stuck on a if Condition.. too silly
LutherPaul
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: Stuck on a if Condition.. too silly
So you're saying the data is 'N/A', '0' and you're checking on is not equal to 'N/A' or is not equal to '0'.LutherPaul wrote:the condition translates to
EndIf;
Isn't that your issue? Otherwise you need to be a bit more clear on what you expect to happen inside and outside of the if statement.
Michel
LutherPaul
Thanks Michel for replying.
I have bad data coming in with values like 'N/A', '0', 'ASDF', which I want to avoid.
When the data is not in ('N/A', '0', 'ASDF'), I want my if to work else, nothing.
Hope I am clear.
Paul.
Hope I am clear.
Paul.
- gtonkin
As Michel said, you need ANDs , not ORs i.e. not blank and not N/A and not 0 etc.
Its sometimes easier to say if something is equal to such and such then itemskip.
True. In Metadata and Data tabs with more than a handful lines of code, I tend to use Itemskip and Itemreject first.declanr wrote:With code like this you are sort of applying a double negative... if the project code is "N/A" it can't also be blank so by using an or on it; the "N/A" gets through as it is not blank or 0.Code: Select all
All other cases that remain will be treated with the remaining code.
- Michel Zijlema
I second that. To me it was not clear whether the If statement enclosed an ItemSkip or the actionable code...declanr wrote:Its sometimes easier to say if something is equal to such and such then itemskip.
I would reverse the conditions and put an ItemSkip inside the if and the actionable code after the endif.
Otherwise (the actionable code still within the if) the condition should I assume be:
if ( (Proj_code @<> '' & Proj_code @<> 'N/A' & Proj_code @<> '0') % NewBuss @= 'N') ;-
LutherPaul
Thanks. That was stupid of me.
