Raising negative number with fractional powers
bunchukokoy
OLAP Product: IBM Cognos TM1
Version: 10.2.2.x
Post by bunchukokoy »
Hi guys,
Has anyone dealt with this kind of requirement in which there's a formula raising a negative number to a fractional power?
Excel and TM1Web give different results for different samples. What we're trying to make a work-around for is when TM1Web gives #NUM result, when Excel gives a valid result (although this is debatable whichever is correct).
Sample:
((-0.50801678102775)^(1/5))-1
Excel gives -1.8733 while TM1Web gives #NUM error.
Thanks in advance for your feedback.
Re: Raising negative number with fractional powers
Actually, TM1Web doesn't give anything, it's what the TM1 engine returns. You can't use a fractional power in TM1 (in your case the 1/5) so the result is an error in TM1.
Olivier
Version: Tm1 10.2.2fp4 -> 2.09
Excel Version: Excel 2013 - 2019
Post by Olivier »
You could use this kind of formula in TI to pre-calculate the results if practical.
nMthlyRate = ((1+ nAnnualRate  )^( 1/12 ))-1;
I have been using it for rates conversion for example.
HTH
Olivier
