servername FQDN.SYSTEM.NET specify the server name to attach to
port 80 specify the port to attach to
url /ibmcognos/cgi-bin/cognosisapi.dll specify the relative URL to the Cognos entry point
Namespace active directory specify the Namespace ID (not the name) of the namespace to use for authentication or leave empty for anonymous
templocation FS specify either FS or CM. This must match the setting in Cognos Administration
pwt 3
swt 30
OutputLocale en-us
The error is
Thread Name: IBM Cognos 10.2.0 - BI Stability package 1-1
Sample Start: 2014-12-10 14:52:52 GMT
Load time: 173
Latency: 173
Size in bytes: 1509
Headers size in bytes: 216
Body size in bytes: 1293
Sample Count: 1
Error Count: 1
Response code: 401
Response message: Unauthorized
Response headers:
HTTP/1.1 401 Unauthorized
Content-Type: text/html
Server: Microsoft-IIS/7.5
WWW-Authenticate: Negotiate
WWW-Authenticate: NTLM
X-Powered-By: ASP.NET
Date: Wed, 10 Dec 2014 14:52:52 GMT
Content-Length: 1293
HTTPSampleResult fields:
ContentType: text/html
DataEncoding: iso-8859-1
Assertion error: false
Assertion failure: true
Assertion failure message: Test failed: headers expected to contain /set-cookie: cam_passport/
