Just a quick note on a bug we identified in TM1 10.2.2.
It relates to the spread functionality using the input of a "c" into a consolidation in order to clear the content of children cells.
I have a couple of consolidation for which children have all a weight of zero.
In order to take a short cut and test a partial series of steps I needed to zero out manually the content of these consolidations.
To do so I tried to use key in a c into the consolidation and confirm using the prompt Yes/ No box.
The system hang for a second, an error message is returned indicating the "spreading failed, the content of the cells can not be modified".
I could understand that the weight on the children is preventing the spreading to cascade properly into the children cells.
Unfortunately, the server then crash and no specific message is issued in the log file.
To note : Similar "c Spread" into classic consolidation with children weighted as 1 for example works successfully every time.
EDIT : Keen to know if this bug is also impacting you guys with a 10.2.2 server ( Easy to test) or it could be something specific to our environment...
