Rule Dependency Query
Just want to double check before I over engineer...
I have two cubes that I want to be totally independent in order to preserve the Rule Cache in each cube.
If the rule sheet for both cubes reference the attributes of the same dimension via a lookup, something like a prior period lookup then does this create a dependency between my two cubes?
i.e.
in Cube A
['Measure'] = DB ('Cube A' , ......, DB('}ElementAttributes_Period' , !Period, 'Prior') ,....);
in Cube B
['Measure'] = DB ('Cube B' , ......, DB('}ElementAttributes_Period' , !Period, 'Prior') ,....);
My instinctive response is that it does create a dependency between Cube A <---> Cube B as the dependency logic in the engine doesn't care about the direction of the dependency (I assume).
Has anyone done direct testing of this?
Emixam
Re: Rule Dependency Query
Post by Emixam »
I've never done any testing but during server startup, can you see the cube dependency being created ?
12345 [] INFO 1900-01-01 00:00:00:00 TM1.Cube.Dependency Adding cube dependency: Cube 'Cube A' depends on cube 'Cube B'
You could also use
log4j.logger.TM1.Cube.Dependency=DEBUG
in tm1s-log.properties file.
Let us know if you find anything, that's an interesting one
Steve Rowe wrote: Thu Jan 04, 2024 10:35 am If the rule sheet for both cubes reference the attributes of the same dimension via a lookup, something like a prior period lookup then does this create a dependency between my two cubes?
No.
Steve Rowe wrote: Thu Jan 04, 2024 10:35 am in Cube A
in Cube B
This creates a dependency in both cubes to the (attribute cube of the) Period dimension. It doesn't create a dependency between cube A & cube B.
