Cheking File Size
vishalpoddar90
Version: 2.0.76
Excel Version: 365
Cheking File Size
Post by vishalpoddar90 »
Dear All,
Is there any function in TI process to check the size of a file. I tried google and tm1 reference guide but couldn't find anything.
If not, is there a way to get the returnvalue from Executecommand().
Thanks.
Re: Cheking File Size
vishalpoddar90 wrote: Fri Apr 06, 2018 7:00 am Is there any function in TI process to check the size of a file. I tried google and tm1 reference guide but couldn't find anything.
"Size" in what sense; rows, bytes, kilobytes...?
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
If by size you mean bytes,
I have a batch script to get the last modified date of a file, but it can be easily tweaked to get the file size, so the code below:
wmic datafile where Name="Name of File Path\Name of file.csv" get FileSize >> "Put the output to this file.txt"
I then use the "Put the output to this file" as a data source in a TI to load the value into an admin cube
cheers, Mark
macsir
Version: PAL 2.0.9
Post by macsir »
Powershell is the way to go rather than TI processes.
