Rules Passing children
- OLAP Product: Tm1
- Version: 9.5
Based on certain condition I need to pass the childrens of a element in a rule .
Like
DB('Sales',!Customer)
I have to pass all childrens of selected customer .
Whats the function or syntax I can use to achieve this .
Thanks , any help is appreciated.
Like
- macsir
- Version: PAL 2.0.9
Re: Rules Passing children
be more specific?
- OLAP Product: Tm1
- Version: 9.5
Based on attribute value , I I have to pass all the childrens for a selected customer for a certain case and customer itself in certain cases .
or
DB('Sales',Childrens(!Customer))
I am not sure for the syntax to pass all CHildrens(!Customer).
or
- OLAP Product: tm1
- Version: 10.2.0 - 10.3.0
You should understand that the leaves can be located in different hierarchies and you can grab a some problems with this.Analytics123 wrote: ↑Mon Feb 19, 2018 1:02 pm Based on attribute value , I I have to pass all the childrens for a selected customer for a certain case and customer itself in certain cases .
or
Enjoy
['Customer_Flag']=
#Pass value from top hierarhy level
C: IF( ELPARN( 'Customer', !Customer ) >0
,ATTRS( 'Customer' , ELPAR('Customer', !Customer, 1) , 'AttributeName' )
, ATTRS( 'Customer' , !Customer , 'AttributeName' );
#Get value from first parent elemen
S: ATTRS( 'Customer' , ELPAR('Customer', !Customer, 1#number of hierarhy) , 'AttributeName' );
- OLAP Product: Tm1
- Version: 9.5
Hi I need to pass my childrens of the customer in the rule statement .
I was thinking some thing like ELCOMP etc..
I have this already working ,
if(Attrs('CUstomer',!Customer, 'Pass Children')=True, DB('Sales',Children(!Customer)), DB('Sales',!Customer).
I need the equivalent expression to get the childrens of the selected customer .
- OLAP Product: Tm1
- Version: 9.5
Any suggestion on this is appreciated.
Can you think of any other way to get the childrens .
If I use ELcomp it gives only one children. I need to pass all children.
COnsolidatechildren('Customers') worked but not sure that would affect performance.
Any other suggestions is appreciated
- paulsimon
- Version: PA 2.0.5
I suggest that you read the TM1 Rules Guide. There is a section there on changing levels.
You cannot pass children to a rule. TM1 rules do not work on sets.
You can however make a rule at the base level work for all children of a consolidation which effectively achieves the same thing.
- macsir
I don't think there is a way to get all children for a selected parent in the rule. Children function only exists in MDX.
If Consolidatechildren('Customers') by summing immediate children works for you, why can't you create some hierarchies instead for better performance?
- OLAP Product: tm1
In one cell you want to pass that list of children? separated by what?Analytics123 wrote: ↑Mon Feb 19, 2018 3:04 pm I need the equivalent expression to get the childrens of the selected customer .
But of course this can be done BUT WHY?
[]=S:ELCOMP(dimension, element, 1) | ' ; ' | ELCOMP(dimension, element, 2) ...
if you need to transfer some children to a cube, then you need to add another dimension to this cube with the list from 0 to 100
and use the following rule
['List']=S:ELCOMP(dimension, element, !List);
