I have a rule which is
SkipCheck;
[SalesPercentage]= [CurrentSales]\[TotalSales];
Feeders:
[CurrentSales]=>[SalesPercentage]
If I have a negative values for CurrentSales and if total sales is 0 then the cell value calculated is (1,118,559,750,467,500.00)
Anything divided by zero should apply zero right .
negative value divided by zero Issue
- OLAP Product: Tm1
- Version: 9.5
- Alan Kirk
Re: negative value divided by zero Issue
No, anything divided by zero is undefined. Anything divided by zero when using the TM1 \ operator is treated as zero, which is not the same thing. But anything which is divided by a really, really small number which is a stack of places to the right of the decimal point and which looks to you like zero because of formatting but actually isn't is going to result in a freakingly huge (absolute) number like the one you are showing here.Analytics123 wrote:Hi,
SkipCheck;
Feeders:
You may want to put some rounding functions in your rules to overcome that problem.
- qml
- Excel Version: 2007 - 2016
There is also a config parameter that can help solve your problem, which is, as Alan pointed out, that the denominator is small, but not zero.
Kamil Arendt
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Out of interest what happens when the denominator is the extremely small number used in place of null in some instances when we have UNDEFVALS? I would hope that it would realise and treat it as zero.
It's been a while. Is UNDEFVALS still a thing out there?
