Location of System Cubes
- Alan Kirk
We'll never get this, because of course IBM can't be bothered doing any more work on Perspectives so even raising this is like playing Fantasy Football and expecting to personally hold aloft the World Cup, but... am I the only one who thinks that it would be cool if the system cubes and dimensions appeared AFTER the data cubes so that you could still have the things switched on for easy access in Server Explorer but NOT have to wade through them on the more frequent occasions that you need to get to a data cube? (Yes, I know you can press the first key of the data cube to jump to (somewhere near) there, but it would be nice to have them already in your face, IMHO.)
- jim wood
- Version: PA 2.0.7
Re: Location of System Cubes
If you open up the }processes dimension all of the processes used for workflow etc come up first there as well. They should be at the bottom,
Shop at Amazon
Shop at Amazon
- Version: 10.2.1.1
- Excel Version: 14.0.6129.5000
Quite right, it does it for the }cubes and }dimensions dimension, so why not }processes.If you open up the }processes dimension all of the processes used for workflow etc come up first there as well. They should be at the bottom
You could Sort the dimension order by Automatic and Name.
