PCA-ERR-0001 error with Tm1 data source
santu469
Post by santu469 »
Recently we started getting an error in cognos BI while trying to access packages created on TM1 data source from one server. Here is the error:
There is a PCMDDS internal error at "tm1odpCube.cpp":"1,524".
There are about 10 cubes in this server and error comes for 6 of those cubes and the Packages created on the other 4 cubes are working fine. We restarted both conogs BI and TM1 servers still no luck. There were no any metadata changes on TM1 server except data refresh. I couldn't find any working solution :(
jaudouig
OLAP Product: TM1, Transformer
Version: TM1 9.5
Re: PCA-ERR-0001 error with Tm1 data source
Post by jaudouig »
I know it's been a while, but have you found a solution for this issue?
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
jaudouig wrote:Hi,
If it is the issue mentioned here, than from the the article:
stop and restarting the BI server will synch things up
Or, more permanently:
Upgrade to IBM Cognos 10 Business Intelligence 10.1.1 Fix Pack 1
Michel
