Deal all,
As far as I know, textoutput() or asciioutput() always contain the starting symbol:", also the end symbol.
for example, as running a TI
##in Prolog
sStrings='testtext';
textoutput('ouput.cma',sStrings);
after TI completed, open the ouput.cma, and it shows:
"test"
but what I expect is:
test
does any know how to solve this issue?
I want to use textoutput to create txt file for create rule by TI,
do I have another option to achieve this?
how to set the statrt and the end symbol in TextOutput()?
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Re: how to set the statrt and the end symbol in TextOutput()
This is controlled by the TI variable DatasourceASCIIQuoteCharacter which you can set to the empty string ''. You might also want to look at DatasourceASCIIDelimiter.
Jeroen Eynikel
Duncan P wrote:This is controlled by the TI variable DatasourceASCIIQuoteCharacter which you can set to the empty string ''. You might also want to look at DatasourceASCIIDelimiter.
Great! :p
solverxyz
- OLAP Product: NONE
- Version: TM1 9.5.2
thank you so much~~~~~~~~
it's really helpful
it's really helpful
