9.5.1 Hotfixes
9.5.1 Hotfixes
This thread will be used to keep track of known hotfix releases for 9.5.1. Rather than "sticky" this thread I've added links to the hotfix release threads for various versions (including this one) to the FAQ post. I'll update this thread and the other ones as further hotfixes are released.
See also: What Hotfixes are, and how to install them..
Hotfix 1 for TM1 9.5.1 (aka TM1 9.5.1 HF1)
This is an internal hotfix which addressed an issue in a future release of IBM Cognos Express.
Hotfix 2 for TM1 9.5.1 (aka TM1 9.5.1 HF2), 28-JUL-10
COGCQ00270147 (PM17715) TM1 API - TM1ObjectAttributeValuesSet showing error [37] ObjectAttributeInvalidType (server fix)
Hotfix 3 for TM1 9.5.1 (aka TM1 9.5.1 HF3), 16-AUG-10
PM18707 Wrong display of cyrillic characters in TM1 Workflow
951_HF3_workflow.zip contains two files:
TM1 Planning Manager.xla
sm_upgrade_v951_HF3.pro
Install 9.5.1 workflow. Extract the content of the 951_HF3_workflow.zip file to a temporary folder. Copy the new 9.5.1 HF3 TM1 Planning Manager.xla into the bin directory. Additionally, the sm_upgrade_v951_HF3.pro file should be added to any database that Workflow will be used with.
Once the .pro (new TI process) has been added, start the server and run the process. It will default to Tahoma for the font and 204 for the character set - those are the necessary settings to display the basic Russian alphabet.
Hotfix 4 for TM1 9.5.1 (aka TM1 9.5.1 HF4), 18-AUG-10
COGCQ00260150: Freeze pane in active form causes picklist to open behind the frozen area instead in front (web)
COGCQ00266894: simple conditional format in active form dont work in tm1 web but in excel (web)
COGCQ00269091: Error using a subset for an Approval Hierarchy in Contributor (server)
COGCQ00269253: Cursor jumps to first column of a view when selecting an element from a column picklist that is off the viewable web page (web)
COGCQ00270951: 9.5 tm1 server crashing with less than 10 users. (server)
COGCQ00275787: VBA API code runs slower in 9.5 versus 9.4.MR1.FP1 (server)
COGCQ00276026: Selecting a measure with German install for package connector causes client crash (server)
COGCQ00276038: Picklist display within Perspective Server Explorer on a client workstation is slow (client)
COGCQ00276069: Paste into cell with picklist is still allowed in Server Explorer even though it is not allowed in TM1Web, thin client or Excel slice. (client)
COGCQ00276072: Missing the Column width menu item from the cube viewer Options drop down list (client)
Hotfix 5 for TM1 9.5.1 (aka TM1 9.5.1 HF5), 21-SEP-10
PM20576 TM1: canceling a submitted job via the queue manager does not always succeed
PM20789 TM1: committing job generates 'Error' status
PM20948 TM1: blue triangles randomly left in Excel workbook after commit/refresh
PM09543 TM1 Contributor Column Misalignment
Hotfix 6 for TM1 9.5.1 (aka TM1 9.5.1 HF6), 01-OCT-10
PM19611 Dynamic subsets do not work in TM1 Web
PM20518 Migrating Active Forms From TM1 9.5.0 to 9.5.1 gives error an in TM1 Web "System has encountered a problem while handling your request. Please try again. If you keep having trouble, please contact your system administrator for assistance."
PM20656 Operation Failed" error in opening the web sheet having images on the first sheet of xls file
PM21941 Server crash when loading Contributor
PM22394 TM1 Crash - Server crashed and had created a DMP file
PM22680 Server Crash During Server Start - TM1TransactionLog::Initialize: Failed open write while performing append check on the transaction log.
Hotfix 7 for TM1 9.5.1 (aka TM1 9.5.1 HF7), 01-OCT-10 (Date may be approximate)
PM21501 TM1 Workflow Client for TM1Web does not show tasks for which users are responsible
Hotfix 8 for TM1 9.5.1 (aka TM1 9.5.1 HF8), 22-OCT-10
PM13064 Tm1web using freeze Pane in Firefox - scrolling does not synchronize between the Headers and Rows
PM17301 Drill through issue during navigation cube to cube
PM19848 Excel crashing
PM20964 'Passport Error' logging into Architect through SiteMinder
PM22340 dynamic subset issue
PM21069 Text disappears on Action Button formatted as a hyperlink on Web
PM22104 The TM1 C API function TM1ObjectAttributeValuesSet cannot process Unicode characters
PM22931 Server crash when running TI process
PM22500 Data Spreading on websheet works despite having "Allow Cell Write Back from Web" option disabled on worksheet
PM23173 TM1 Contributor column misalignment
PM22760 Tm1 web reports working in 941 FP3 but not in 9.5.1
PM23306 TM1 server crash when entering data in the contributor grid
PM20500 if the measure format set the %, we cannot show the right number when copy&paste the excel data in the Cube Viewer
PM24474 Locking issue
CAM Regression: Server crash when trying to log in.
splash screen must be updated with 2011 info
TM1 API calls are leaking memory when used repeatedly
[PERF-LAB] TM1 Master Detail report is significantly slower in IB 4707.18 (Classic Stack) in comparison to Cognos 8.4.1 RP-1 at a 300 user data point
Hotfix 9 for TM1 9.5.1 (aka TM1 9.5.1 HF9), 12-NOV-10 (?)
Applies to: x86 (client, server, web) & x64 (server & web)
PM21794 One char can be typed in to cell in TM1 Web against Firefox
PM18981 Export from TM1 Contributor limited to 245 rows
PM23155 TM1 websheet headers not recalculating with WebsheetPaging enabled
PM23413 TM1 Web: Paging set but not returning proper information
PM23422 Row Headers become misaligned when doing a Find (Ctrl F) in Internet Explorer
PM24264 Customer cannot cut and paste into TM1, gets VB runtime error
PM24814 Websheet Rebuild should reset the paging toolbar values to the default Paging values. (See below for further info.)
PM25043 TM1 Server Crash
PM25816 TM1 Server crashing when working in Contributor
Data entry problem in TM1 Web Cubeviewer
Entering invalid cell data causes sheet to fail on web
[PERF-LAB] TM1sd faults during 25 user test.
c10 pkg conn: Architect crashes when saving a Package Connector process
[PERF-LAB] Significant TM1 memory growth while running 5 user TM1Planner test
TM1 Workflow exceptions when try to enable traditional CXL (a.k.a TM1) menu in Excel 2007 in Cognos Express v95
[PERF-LAB] Performance degradation with first open of TM1 C8 Authored reports (CX)
Additional Configuration required for PM24814
To enable the new behavior you would specify a 'PageResetMode' value of '1' in the web.config under the 'websheetpaging' settings.
Example:
    <!-- Websheet Paging Settings -->
    <add key="WebsheetPaging" value="Enabled=true;PageSize=10;PageResetMode=1" />
Hotfix 10 for TM1 9.5.1 (aka TM1 9.5.1 HF10), 09-DEC-10 (?)
PM21809 Extra characters are added into TM1 web when copy and paste from Excel
PM23315 Excel crashes when un-checking "Suppress zeroes" in TM1 Perspectives sheet
PM22750 Sort on WEB does not work the same as Excel
PM23056 When TM1 Web users copy/paste values, get html tags embedded with them
PM23338 C8ITK Client does not handle compressed data correctly
PM13393 When large cube view with multiple pages is opened, the row number of the last line disappears.
PM24378 To open a websheet a second time fails with MSIE error message "SandboxQuery is undefined".
PM25728 CTm1web - Exporting to excel- error Excel could not open the Xml spreadsheet:Exception from HRESULT: 0x800A03E
PM25771 When TM1 Web users copy/paste values, get html tags embedded with them
PM18999 DataAdmin getting Permission Denied error when creating a dim via TI
PM25863 TM1 Web Recalculate in action button does not write values to cube
PM17093 You do not belong to a group. Please see your TM1 administrator.
PM26138 With the TM1 9.5.1 HF8 Server Software for Windows x64, in a dimension having element security assignments the UDC and Rollup functions fail to work when executed by a non-ADMIN user.
PM26323 Beta - 8/5 Blitz - Crash1
PM25918 TM1-Server-Crash
PM25672 TM1: server crash on load
PM26548 SaveDataAll does not update feeder files to be current
PM26975 Cannot Paste into a Cell with Data Validation * See notes below
Requires config parameter to enable.
Add the following config parameter in the web.config file anywhere under appSettings:
<!-- Paste Enforcement Settings -->
<add key="PasteEnforcement" value="mode=1"/>
value name(s):
'0' or no value (default) or 'Strict' - current 9.5.x behavior of no pasting into validation cells
'1' or 'IgnoreValidation' - pasting is not validated (like in 9.4.x, etc)
Hotfix 11 for TM1 9.5.1 (aka TM1 9.5.1 HF11), 23-DEC-10 (?)
PM25633 Performance (analysis studio, query studio, cognos viewer) significantly deteriorate when executed as a consumer who has TM1 cell based security applied.
PM25644 TM1 save all data - read / write lock
PM25800 Formatting not consistent between thick client and web client
PM26743 Contributor exports numeric values as text to Excel after applying Hot Fix 9
PM27495 Core crashes TM1 server during execution of 9th process
PM26680 In TM1 v9.5.1, Unable to run two specific processes in parallel
PM28285 When pasting value with embedded commas into multiple cells, commas are removed
ExApplix
OLAP Product: Cognos Tm1
Re: 9.5.1 Hotfixes
Post by ExApplix »
To apply the HF2, do we first have to apply HF1?
Re: 9.5.1 Hotfixes
ExApplix wrote:To apply the HF2, do we first have to apply HF1?
Hotfixes are cumulative. HF2 includes HF1. HF3 will include HF2 and HF1, and so on.
LoadzaGrunt
Version: LoadzaVersions
Excel Version: LoadzaVersions
Re: 9.5.1 Hotfixes
Post by LoadzaGrunt »
Thanks Alan,
Do you know the release date for 9.5.1 HF2 ?
Re: 9.5.1 Hotfixes
LoadzaGrunt wrote: Do you know the release date for 9.5.1 HF2 ?
Yes, that would be the bit on the end there.
I wrote:Hotfix 2 for TM1 9.5.1 (aka TM1 9.5.1 HF2), 28-JUL-10
I downloaded it myself this morning, so it's definitely there.
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Re: 9.5.1 Hotfixes
Post by Andy Key »
Alan,
I think you might be looking at the date you downloaded it rather than the release date. The date of the HF2 files on the FTP site is 26-Jul-10.
Andy Key
Re: 9.5.1 Hotfixes
Andy Key wrote: I think you might be looking at the date you downloaded it rather than the release date. The date of the HF2 files on the FTP site is 26-Jul-10.
I got a notification of release from IBM this morning. Well, last night technically, my time. It's entirely possible and even probable that they finalised and packed them a day or so before release, but that's neither here nor there; the point is that they're out there this very day, as we speak even.
LoadzaGrunt
Re: 9.5.1 Hotfixes
Thanks. Where are you getting the release note items from ?
I'm getting conflicting information about when hotfixes are coming out and what will be in them - so I'm just looking for definitive information...
Re: 9.5.1 Hotfixes
Directly from IBM Support. I'm a little surprised that they aren't being embedded in the zip files, but I'd expect that support would normally supply them to people who may have issues outstanding which are rectified by the relevant HF.
LoadzaGrunt wrote:I'm getting conflicting information about when hotfixes are coming out and what will be in them - so I'm just looking for definitive information...
Sorry, I don't have any information on what's coming out in the future, just the notes on what has been released. Actually I don't have all of those either; I don't have the skinny on 9.1.4's latest HF (15) but I'm going to see if I can get a copy of that as well.
Re: 9.5.1 Hotfixes
Hotfix 3 has been released but given that the release addresses only one problem ("Wrong display of cyrillic characters in TM1 Workflow") it's probably going to be of less than universal interest. Still, if you're a Russian user, it's out there...
Re: 9.5.1 Hotfixes
Hotfix 4 has been released. (Actually it was released about a week ago but I only found out about it this morning and had to get Iboglix to send me the details.) I would recommend that anyone who is using 9.5.1 take a look at this one (details in the main post of this thread) since it seems to address a substantial number of issues in that version.
dubs
Version: 9.4
Re: 9.5.1 Hotfixes
Post by dubs »
I've applied the latest 9.5.1 hotfix but when I check the version in the 'about' splash screen it is showing 9.5.1, wheras I'd expect it to show something like 9.5.10004 can someone else with HF4 installed verify that on the splash screen it still just shows 9.5.1?
Many Thanks
Re: 9.5.1 Hotfixes
dubs wrote:I've applied the latest 9.5.1 hotfix but when I check the version in the 'about' splash screen it is showing 9.5.1, wheras I'd expect it to show something like 9.5.10004 can someone else with HF4 installed verify that on the splash screen it still just shows 9.5.1?
It's a hotfix. Cosmetic changes aren't the priority in hotfixes from any supplier.
The version on the .exe files has changed from 9.5.10000.5424 to 9.5.10004.7950. The splash screen hasn't. When the next actual maintenance release / service pack / fix pack / whatever they're calling it this week is released, the "About" menu should be something that they'll change. (Whether it will or not is another matter.) Where it's a fix to bugs in the code, not so much.
dubs
Version: 9.4
Re: 9.5.1 Hotfixes
Post by dubs »
Hi Alan,
Thanks for this, makes sense - actually looking at the log shows that the hotfix has been applied. I too was a bit confused between maintenance release, fixpacks and hotfixs but i gues a hotfix is like a patch where a maintenance release is like a service pack.
cheers
grj52276
Version: 9.5.1
Re: 9.5.1 Hotfixes
Post by grj52276 »
Alan,
Wondering where thse fixes are available. Have been looking for them unsuccessfully
GJ
PlanningDev
Version: 2.0.5
Re: 9.5.1 Hotfixes
Post by PlanningDev »
Ive searched all over the IBM Cognos Support site including Fix Central and I can't find any mention of Fix Packs for version 9.5.1. Where are you guys finding the Hot Fixes? Can you post the link?
Re: 9.5.1 Hotfixes
PlanningDev wrote:Ive searched all over the IBM Cognos Support site including Fix Central and I can't find any mention of Fix Packs for version 9.5.1. Where are you guys finding the Hot Fixes? Can you post the link?
From the main post:
PlanningDev
Version: 2.0.5
Re: 9.5.1 Hotfixes
Ahh yes,
Sorry for the hasty reply before FULLY reading the thread. I was able to update to HF4 but was wondering if anyone noticed that TM1 web doesn't render long picklists? The shorter ones still show up but the longer ones don't even look as if they are attempting to read (no CPU activity when clicking the dropdown) just a blank box.
cmegathlin
Re: 9.5.1 Hotfixes
Post by cmegathlin »
I just visited the IBM download site. There is now a Hot Fix 5 for v9.5.1. It was released on 9/14/10.
laenen
Version: 9.5
Re: 9.5.1 Hotfixes
Post by laenen »
Hot Fix 6 was just released.
