Old TM1 version
Posted: Thu Jan 10, 2019 4:12 pm
by CellPutN
I'm using tm1 since 2016 and I always wonder what older TM1 (Sinper TM/1, Applix TM1) looks like ? Did Sinper and Applix have always used architect ? Did anyone have screenshot of older version ?
Thanks !
Re: Old TM1 version
Posted: Thu Jan 10, 2019 4:31 pm
by jim wood
Architect only came with version 7. Before that it was very different. Everything was built in to Excel. Even loading data as there was no TI either.
Re: Old TM1 version
Posted: Thu Jan 10, 2019 6:44 pm
by Alan Kirk
jim wood wrote: ↑Thu Jan 10, 2019 4:31 pm
CellPutN wrote: ↑Thu Jan 10, 2019 4:12 pm
Thanks !
Or built into Lotus 1-2-3. There was a time when Excel support was New! And! Exciting!
From the Perspectives 2.6 manual, this is what the ancestor of Cube Viewer looked like:
- CubeViewer.jpg (114.79 KiB) Viewed 5480 times
And this is what Subset Editor looked like. Unsurprisingly there were no alias buttons at that time, because the concept of an alias had yet to exist:
- SubsetEditor.jpg (132.08 KiB) Viewed 5480 times
That functionality is still there in the form of the "Example" and "Process" buttons on the ribbon tab, though I'd lay odds that 95% of TM1 users have never looked at those or know what they mean. There was a VBA based tool (once Excel support came along) which sat over that which you could use to schedule the imports. It was about as reliable as a first generation steam train (as in, Stephenson's Rocket, but less robust) and although I used to use the thing daily I cannot for the life of me remember its name now. My then-boss later-assistant used to loathe it with a passion. (At least it was less finnicky than PAW.)
But who could forget the ability to import / export similarly formatted spreadsheets?
- ImportSpreadsheets.jpg (115.8 KiB) Viewed 5480 times
{Pauses... stands up, looks over shoulder in the general direction of 1999, looks at 2019 calendar on the wall....} What the hell just happened?
Re: Old TM1 version
Posted: Thu Jan 10, 2019 8:53 pm
by bgregs
@Alan Kirk,
My god that explains the random macros that I stumbled across!! These are still hanging around as of PA 2.0 under the name "IMPEXP_WORKS" and can still be mapped into the Quick Access Ribbon by looking under the "Macros" drop-down.
Re: Old TM1 version
Posted: Thu Jan 10, 2019 9:41 pm
by Alan Kirk
Alan Kirk wrote: ↑Thu Jan 10, 2019 6:44 pm
Ah, now I remember. It was called "Data Control". Clearly a suppressed memory.
bgregs wrote: ↑Thu Jan 10, 2019 8:53 pm
@Alan Kirk,
That's not surprising; I don't think that the Perspectives add-in has been cleaned out in a very, very long time. Whether the functionality still works equally in 32 bit and 64 bit is a different matter given the issue with something as basic as the
xdi dimension open function. The intention was that PAx would be the cleanout, but, hey... PAW and the curse of Docker. So the legacy code lives on.
Re: Old TM1 version
Posted: Fri Jan 11, 2019 7:22 am
by Michel Zijlema
And if we go even further back in time
... there was this interface:
- TM1_4.0.png (77.96 KiB) Viewed 5441 times
Re: Old TM1 version
Posted: Fri Jan 11, 2019 12:25 pm
by jim wood
I forgot all about Lotus. I used to love Lotus. With the power keys you could do everything without touching a mouse it was awesome!!
Re: Old TM1 version
Posted: Tue Jan 15, 2019 12:54 pm
by CellPutN
Wow thanks guys !
Nice to see how TM1 / PAW has improved over years !
