Creating a }Picklist cube in a TI process
Harvey
Version: TM1 8.3 onwards
Excel Version: 2003 onwards
Post by Harvey »
I'm trying to create a picklist cube for an existing cube using a Turbo Integrator process.
I'm creating a cube with the correct name (}Picklist_Cube_Name) with the same dimensionality as the original cube with the addition of the }Picklist dimension as the final dimension. I'm then attaching a rule to the picklist cube using the RuleAttach TI function.
The code is a little complex, but a simplified version would look like this (given an existing cube called "Cube001" with 3 dims):
sD1 = "dim1';
sD2 = "dim2';
sD3 = "dim3';
sTargetCubeName = 'Cube001';
sPicklistCubeName = '}Picklist_' | sTargetCubeName;
sPicklistDimensionName = '}Picklist';
## Assume this file exists and contains valid picklist rules!
sPicklistRuleFile = '..\source\Cube001_Picklist.txt';
IF(CubeExists(sPicklistCubeName) = 1);
	CubeDestroy(sPicklistCubeName);
ENDIF;
CubeCreate(sPicklistCubeName, sD1, sD2, sD3, sPicklistDimensionName);
RuleLoadFromFile(sPicklistCubeName, sPicklistRuleFile);
This code creates a valid picklist cube with the rule attached, but unfortunately, the picklist only shows up in the target cube after I re-start the server.
I've tried unloading the cube, and selecting "Create Picklist Cube" in architect, but neither work. I don't think the issue is with the structure of the picklist cube itself, since it does work once the server is re-started.
Has anyone tried this? Is there a trick I can use to refresh the picklists once the picklist cube is created? Any help would be appreciated!
Harvey.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: Creating a }Picklist cube in a TI process
Post by Elessar »
Try to call SaveDataAll in epilog
TM1 and Data Science blog: 6th article - PAfE + VBA: Commit each cell without pressing “Commit” button.
Harvey
Post by Harvey »
SaveDataAll doesn't seem to make any difference.
What I have discovered is that the picklist works the first time the cube is created, but once it's established I can't delete it and re-create the picklist cube.
For now I'm just going to leave it if it already exists and replace the rule file. That will work well enough for my purposes.
I would still like to know the answer if there is one, though.
babytiger
OLAP Product: Cognos TM1, EP, Analyst
Post by babytiger »
Have you tried unloading picklist target cube, and then reload the target cube (create a one cell cube view and access it).
Suspect there is a cube dependency on picklist cubes. Destroying the picklist cube may have removed this dependency.
MK
