GetProcessErrorFileName()
I've got a process that uses a text file as a data source, with the name of the file to be processed one of the input parameters. If a user provides an incorrect file name the process obviously bombs and produces an error log file. I would like to get the name of that error log file using GetProcessErrorFileName() but it doesn't work. According to the IBM documentation, the value in this variable is only available after the completion of either the prolog, metadata or data tabs. My error is in the prolog but since it is fatal the prolog never finishes and the variable is empty. Does anyone know of a strategy for executing a process and getting the value from GetProcessErrorFileName() when a fatal error occurs in the prolog?
Re: GetProcessErrorFileName()
Can't you just avoid the fatal error? Test for the existence of the source file and if it isn't there set datasource type to null and itemreject to create the error file. Then on the epilog pick up the error file name ...
Thanks for the idea. That's what i was thinking I was going to have to do, I was just wondering if there was some sort of way to get the error log file name without resorting to that.
How do I set the DataSourceType to null? NULL doesn't exist in TM1. I tried setting it to an empty string and the process just tries to use the file I have specified in the data source tab instead of not trying to open anything. Here is my code:
sPath = CELLGETS('Global Variables', 'Value', 'Path to Hierarchy Files');
IF(FILEEXISTS(sPath | pFileName) = 0);
DATASOURCETYPE= '';
ITEMREJECT('File is missing');
PROCESSBREAK;
ELSE;
DATASOURCENAMEFORSERVER= sPath | pFileName;
ENDIF;
- Version: 10.2
Try this:
DATASOURCETYPE= 'NULL';
PROCESSBREAK;
ELSE;
ENDIF;
PROCESSBREAK;
ELSE;
ENDIF;
That doesn't work, the process still tries to open the file, even though it doesn't exist. What I ended up doing is this:
DATASOURCETYPE= 'SUBSET';
DATASOURCENAMEFORSERVER= '}Clients';
DATASOURCEDIMENSIONSUBSET= 'All';
PROCESSBREAK;
ELSE;
ENDIF;
- Alan Kirk
It didn't work because there's a bug in your logic; when you execute the ItemReject the Prolog stops executing and moves on, exactly as it does if you use the statement on a Data record. Therefore it never hits the ProcessBreak line, therefore it does not bypass the Metadata and Data tabs.tomok wrote: ↑Wed Jun 06, 2018 5:51 pmThat doesn't work, the process still tries to open the file, even though it doesn't exist. What I ended up doing is this:What I am doing is setting the source to be a subset that I know always exists, whenever the file does not exist. The subset never gets processed because I send an error message to the log and then do a break. Not ideal but it does work.Code: Select all
IF(FILEEXISTS(sPath | pFileName) = 0); DATASOURCETYPE= 'SUBSET'; DATASOURCENAMEFORSERVER= '}Clients'; DATASOURCEDIMENSIONSUBSET= 'All'; ITEMREJECT('File is missing'); PROCESSBREAK; ELSE; DATASOURCENAMEFORSERVER= sPath | pFileName; ENDIF;
Because of the restrictive nature of GetProcessErrorFileName(), I never use the thing. Instead I use GetProcessErrorFileDirectory to get the path and append my own (usually more descriptive) file name. I then AsciiOutput that. That allows the ProcessBreak to execute.
That makes sense. I changed the logic to this and it works like I want it to now:
Prolog:
IF(FILEEXISTS(sFile) = 0);
PrologError = 1;
ITEMREJECT('Hierarchy file ' | sFile | ' not found');
ELSE;
DATASOURCENAMEFORSERVER= sFile;
ENDIF;
MetaData (at the top):
IF(PrologError <> 0);
PROCESSBREAK;
ENDIF;
I realize I could do something with EXECUTEPROCESS to control this stuff but I don't like to use that due to internal issues. Process changes have to go through a lot of red tape because of SOX but I can can change chores any time I want.
- Version: PAL 2.0.9.18
Hi Tom,
Related coding can be found here, though it's not using GetProcessErrorFileName() but rahter ExecuteProcess of a generic process that tests the file.
IBM Champion 2024
IBM Champion 2024
- Version: 10.2
Insetad of ITEMREJECT, I use LOGOUTPUT, which a new TI Function (from Version 10.2.2x) and then I use PROCESSQUITtomok wrote: ↑Wed Jun 06, 2018 5:51 pmThat doesn't work, the process still tries to open the file, even though it doesn't exist. What I ended up doing is this:What I am doing is setting the source to be a subset that I know always exists, whenever the file does not exist. The subset never gets processed because I send an error message to the log and then do a break. Not ideal but it does work.Code: Select all
IF ( FILEEXISTS ( sDataSourceFile ) = 0 ) ;
sReturnMessage = 'INVALID_DATA_SOURCE_FILE: ' | sDataSourceFile ;
CELLPUTS ( sReturnMessage , cubUserParams , sUserName , elmActionButtonMessage ) ;
LOGOUTPUT ( 'ERROR' , 'Process executed by user ' | sDisplayUserName | ' was teminated with error code: ' | sReturnMessage ) ;
PROCESSQUIT ;
ELSE ;
DATASOURCETYPE = 'CHARACTERDELIMITED' ;
DatasourceASCIIDelimiter = ',' ;
DATASOURCENAMEFORSERVER = sDataSourceFile ;
DATASOURCENAMEFORCLIENT = sDataSourceFile ;
ENDIF ;
