Hi, I am creating a new Windows 2012 environment with BI + TM1 10.2.2 (PreProd). All the installation is working (BI, Framework, Architect, Modeler, pmpsvc, tm1web...), but Package Connector is greyed out into Turbo Integrator. I tried all KB I found. Reviewing my checklist: IBM Package Connector is installed; Gateway and Dispatcher are configured; TM1_PACKAGE_CONNECTOR environment variable is set to the {packageinstalldir}\bin; The server was restarted; Package temp folder rights were reviewed; Tried to open Architect as Administrator.
Any ideas?
TM1 Package Connector is disabled
- tiagoblauth79
- OLAP Product: Cognos BI and TM1
- Excel Version: 10
- qml
- Excel Version: 2007 - 2016
Re: TM1 Package Connector is disabled
Do you have the Package Connector installed on the machine where you are running Architect (as well as on the server)?
Kamil Arendt
- tiagoblauth79
- Excel Version: 10
Yes, I do. Thanks for the tip.
- Excel Version: Excel 2007
Ensure you are running the 32-bit version of Architect (from the bin directory, not bin64).
Package Connector DLLs are 32-bit and cannot be loaded into a 64-bit Architect process.
